E-fan Relay Question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-14-2012, 10:00 PM Thread Starter
adams91lx's Avatar
Question E-fan Relay Question
Figured you guys might know...
I'm wiring up my e-fan... I need to know if the standard 5-pin relay socket is strong enough to handle the 80A relay I'm hoping to plug into it.
Is there a heavy duty relay socket?
Thoughts?
Thank you Corral!
-Adam
1980 Mustang Coupe, 5 lug, daily driver...
http://i73.photobucket.com/albums/i231/adams91lx/lonely_coupesig.jpg
adams91lx is offline
post #2 of 4 Old 06-17-2012, 10:54 AM
80 amps (if you're actually flowing 80 amps of current) needs 10gauge wire. You'll have to use your best judgement if you think the connectors are actually intended for use with wires that heavy.
However I rather doubt you're going to see 80 amps of load from your fans.
Megasquirt
seijirou is offline
post #3 of 4 Old 06-17-2012, 10:53 PM
wmburns's Avatar
To keep the voltage drop within limits, #10 wire should be limited to 30 amps. #8 is generally good for 50 amps.
wmburns is offline
post #4 of 4 Old 06-18-2012, 12:03 AM
Is that correct for 12v DC?
Megasquirt
seijirou is offline
using a temp sender to trigger fan relay rforres General Mustang Tech 8 05-18-2012 05:15 PM
70 amp factory fan relay for electric fans rforres General Mustang Tech 0 05-16-2012 11:15 PM
fan and cooling question clean89 94/95 Tech 1 06-17-2011 11:59 PM
electric fan: fan speed controllers? BerniniCaCO3 General Mustang Tech 21 03-23-2011 09:29 PM
MARK VIII fan relay? 99redsnake 5.0/5.8 Engine Tech 8 11-27-2001 08:45 PM
