Voltmeter acting weird - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-13-2012, 08:40 PM Thread Starter
blackbeast98's Avatar
I hooked up a autometer voltmeter the other day and it worked fine for a day, today i drove the car and it was working fine, turned it off and it had stopped working. so long story short i removed it tested it on a batt. it worked ok, then cleaned the ground plugged it back up and it began to read 12volts. I then re installed it got everything hooked back up and it does nothing again!!
I have it hooked up to the radio acc wire, its still hooked up radio works and everything, i do have the gague and the gauge light grounded to the same spot. the light still works fine but the gauge is dead again. Any suggestions? Its got to be a wire i would think but there all still tight and hooked up.
blackbeast98 is offline
post #2 of 5 Old 06-13-2012, 09:54 PM
What are you getting with a DVM at that wire with radio on and off?
1970 Mach 1 Mustang with SoT bilsteins and mid-eye 4 1/2 leafs 620lb drop springs in the front. *393 4V cleveland with Buddy Rawls custom solid cam Astro A5*
Reverb is offline
post #3 of 5 Old 06-13-2012, 10:28 PM Thread Starter
It got dark on me b4 i could test it but could the ground wire being to thin make it act up?
post #4 of 5 Old 06-14-2012, 02:07 PM
Try grounding it to a different spot and if that doesn't work try getting your +12v from somewhere else. I try and stay away from the radio wires as thats probably the one place that every owner of my car has had their fingers.
Reverb is offline
post #5 of 5 Old 06-15-2012, 08:36 PM Thread Starter
Turns out it was defective i hooked it to a hot battery and still nothing so i just sent it back
Another weird engine swap raininfire Lounge 51 02-15-2013 05:22 AM
Need Wiring Diagram for Cruise Control System dan89lx General Mustang Tech 6 03-27-2011 07:24 PM
For Sale AEM Wideband, 2 pod A pillar, Voltmeter for sale cobradvm Electronics and Entertainment 0 02-04-2011 08:22 PM
For Sale Autometer fuel pressure, water temp, tach, and voltmeter red93gthatch Electronics and Entertainment 7 12-11-2010 09:20 PM
