High Beams, no Low Beams!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-02-2012, 11:50 PM Thread Starter
ok when I turn on the headlights, the high beams come on. when I pull the lever to flash the high beams, nothing happens. when I push the lever towards the dash to turn the high beams on, the lights turn off. I changed the multifunction switch/light switch/dimmer switch and no change. any ideas??? thanks!
Louis
hammer101 is offline
post #2 of 5 Old 06-04-2012, 10:28 PM
wmburns's Avatar
I wonder what model year Mustang we are dealing with????
Just wondering if you checked the fuses?
If this is a 99-04 MY, are aware there's a separate fuse for each low beam?
99-04 Fuse panel layout:
1999 Mustang GT with 2001 motor swap, wont fire. Please help - Ford Mustang Forums
wmburns is offline
post #3 of 5 Old 06-05-2012, 09:11 AM Thread Starter
91 lx coupe, lol my bad
Louis
post #4 of 5 Old 06-21-2012, 07:52 AM
did you get this fixed? veryify voltage at the wiring harness on the drivers side strut tower. There is a round connector that houses the lighting wiring. Green is High beams, Red is Low, Black is the ground. Sounds like to me though that there is a possible wiring issue to the Multi Function switch. Maybe a short across wires or something causing the high beam to be one in the normal position and the High position to be non-functional. If flash to pass is not working then it would almost have to be wiring of some sort as that is a "seperate switch" as is see it.
bravesman16 is offline
post #5 of 5 Old 06-21-2012, 12:48 PM Thread Starter
Ok my bad for not updating this, but it is fixed. After trying multifunction switches, light switches and dimmer switches, I traced the entire harness out to the bulbs and it was ALL good. Turns out the previous owner put in the wrong headlight bulbs. After the correct ones where installed everything works fine. Waste of time for the wrong bulbs. Lesson: don't ever think the guy before you knows what he is doing! LOL thanks for the help.
Louis
High miles + low boost? metalman302 Turbochargers 11 06-14-2011 10:05 PM
High Beams Only??? KobraLX General Mustang Tech 7 01-08-2002 07:29 PM
1982 GT with high beam issues PurpleGT General Mustang Tech 7 01-03-2002 08:49 AM
1500rpm too low a cruise speed??? MO Stang 5.0/5.8 Engine Tech 17 12-30-2001 07:56 PM
