New blower motor, one speed only? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 06-01-2012, 08:53 AM Thread Starter
blackbeast98's Avatar
Just bought a 98 gt and the guy had the heater core replaced along with the blower motor. Issue is the blower only works on low speed. If you turn it on high or any other speed it still only blows on low. Would that be a motor issue or the switch its self? I think he said it worked ok for a month or two then did this.
Thanks guys
blackbeast98 is offline
post #2 of 7 Old 06-01-2012, 09:34 AM
Goats's Avatar
It sounds like a switch or blower resistor issue. The blower motor itself only has one setting which is hi and the blower resistor drops power to slow it down.
Goats is offline
post #3 of 7 Old 06-01-2012, 02:16 PM Thread Starter
Ok is there a way to narrow it down to either one? Or trial n error
post #4 of 7 Old 06-01-2012, 07:04 PM
Goats's Avatar
Only if you have a volt meter
Goats is offline
post #5 of 7 Old 06-01-2012, 07:25 PM Thread Starter
i have one what would i need to test exactly?
post #6 of 7 Old 06-01-2012, 07:48 PM
wmburns's Avatar
OK, if you look at the wiring diagrams, there's no logical way that a bad blower motor switch could create the OP's symptoms. However, a shorted blower ballast resister could.
To test the blower resister with an Ohm meter, verify there is 1.3 Ohm between terminals 4-3. Between 3-4 should be 0.5 Ohm. Between 1-2 should be 0.5 Ohm.
Or just look at it. Usually the rust through or bunt appearance is a dead give away.
I would also double check that the blower runs at full speed if the blower resister #4 (O/BK) is grounded. Be sure to use a solid ground because the blower needs a lot of current. If the blower does not run on full speed, then consider the blower may have bad bearings.
wmburns is offline
post #7 of 7 Old 06-02-2012, 09:36 AM Thread Starter
thank you sir!
Fan clutch engagement oatburner99 5.0/5.8 Engine Tech 9 06-17-2011 05:03 PM
fan speed settings? BerniniCaCO3 General Mustang Tech 2 04-25-2011 06:36 AM
speed density 5.0 will not idle under 1200 after 5 speed swap!?? compucarnut 5.0/5.8 Engine Tech 7 03-28-2011 10:07 PM
electric fan: fan speed controllers? BerniniCaCO3 General Mustang Tech 21 03-23-2011 09:29 PM
For Sale POSI race ported prototype blower for an 03 cobra jimmy8541 Power Adders 1 12-27-2010 06:31 PM
