One Touch Module problem? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 05-29-2012, 06:26 PM Thread Starter
My 94 Cobra's driver side window motor bushings broke, so I replaced the motor (just the motor, regulator was fine). The replacement motor works smoothly, however when the "one touch down" is depressed the window hits the bottom of the track and the motor keeps running. (clack, clack, clack as the motor gear slips on the regulator rack)
Is there a way to reset the one touch module so that it knows when to stop?
It appears that there are a lot of knowledgeable people on this site.
GlencoeRd is offline
Tags
1994 cobra, one touch module, window motor, window regulator
5.0 intermittent cold start problem (long) EL1XR8 5.0/5.8 Engine Tech 4 10-10-2011 01:57 PM
Brake problem after sn95 swap Jd65 General Mustang Tech 16 08-28-2011 08:39 PM
1968 2v valve stem height problem 68torinomgh 5.0/5.8 Engine Tech 11 08-24-2011 11:28 PM
Is my TFI module dieing?? blackstallion 5.0/5.8 Engine Tech 1 01-07-2002 07:46 PM
Fuel Delivery Problem Solved!! Blown46Cobra GT & SOHC 9 12-18-2001 01:44 PM
