what could be causing this? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-23-2012, 02:59 PM Thread Starter
put a new headlight switch in my 99 cobra bc only thing that would come on was the headlights (no tails,dash or fogs)
when i pull the knob all the way out only the headlights come on no dash lights or anything....but if i barely push the knob back in and i mean barely the dash lights,fogs and tails will come on
when i barely push it in i hear a click coming from the front of the car by thr front bumper
is there somekind of relay or switch located up there that could be causing this?
replaced headlight switch twice, checked all fuses multiple times, checked all wires behind cluster and headlight switch
please help
98dropta is offline
post #2 of 2 Old 05-25-2012, 02:47 PM
wmburns's Avatar
Fog light relay in the battery junction box is most likely making the clicking noise.
I'm going to assume that you have doubled check all fuses and that can't possibly be your problem.
Further going to assume the switch is good.
Then the most likely issue is a poor connection to the head light B2 (TN/WH) gang. There is a detailed pinpoint test in the 1999 Ford service manual (149-001). If interested in getting a copy for yourself, I maybe able to help. PM if interested.
If this were my car, I would inspect the wire harness connectors at the headlight switch itself. Look for evidence of heat damage. What may have happened is prior over heating events have damaged the connector thus making a poor electrical connection.
wmburns is offline
Aftermarket/ Dealer Installed Alarm Causing Ignition trouble? Pushrods 94/95 Tech 0 04-24-2012 09:07 AM
AC Condenser fins causing an overheat? jruppert 94/95 Tech 6 08-21-2011 10:43 PM
what's causing my tires to scallop? pmagee Lounge 12 06-21-2011 09:31 PM
Rims chipping on inside causing a leak from6to8 94/95 Tech 6 11-21-2010 03:01 PM
Is my fuel filter causing FP problems? FastDriver 5.0/5.8 Engine Tech 9 12-06-2001 08:28 PM
