Red wire with green stripe....HELP - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 05-21-2012, 06:32 PM Thread Starter
80Mustang351's Avatar
I found a very hot wire,It is coming from my ignition,when i trun the key to start the car it dont start,so i started to put the steering column apart to look at the wiring,The Red wire with green stripe is the one getting hot,The car will start from the solenoid and the wire inside the car will still be hot.
HELP!!!!!!!!!!!
80Mustang351 is offline
post #2 of 14 Old 05-21-2012, 09:44 PM
Sprayaway Fox's Avatar
With the key off its it hot yet? If it is its one of the constants that when you slide your switch powers the rest of the system. I beleive the yellow wires are also constants.
Sprayaway Fox is offline
post #3 of 14 Old 05-22-2012, 11:27 AM Thread Starter
Nope its only when the key is on.
post #4 of 14 Old 05-22-2012, 08:39 PM Thread Starter
Ok so i tryed a few things 1 i got a new coil,red with lite green wire still getting hot,Ignition module is good had it tested.So now what it be?
post #5 of 14 Old 05-22-2012, 08:45 PM
Question
Think the Green w/Red wire also is the output wire from the Alternator Regulator. www.veryuseful.com
racerxmdd is offline
post #6 of 14 Old 05-22-2012, 08:57 PM Thread Starter
Originally Posted by racerxmdd View Post
Think the Green w/Red wire also is the output wire from the Alternator Regulator. http://www.google.com/imgres?hl=en&sa=X&biw=960&bih=516&tbm=isch&prmd=im vns&tbnid=eo0ofZnQHlPUcM:&imgrefurl=http://www.mustangworld.com/forums/showthread.php%3Ft%3D586539&docid=FDf7GmmwZRvihM&i mgurl=http://www.veryuseful.com/mustang/tech/engine/images/fuel-alt-links-ign-ac.gif&w=1122&h=558&ei=njO8T9WqEcL46QGez6ks&zoom=1 &iact=hc&vpx=440&vpy=162&dur=522&hovh=143&hovw=288 &tx=165&ty=90&sig=108637228183966982251&page=8&tbn h=103&tbnw=207&start=83&ndsp=12&ved=1t:429,r:6,s:8 3,i:284
Its the Red With Lite green with tho.
post #7 of 14 Old 05-22-2012, 09:19 PM
post #8 of 14 Old 05-22-2012, 11:23 PM
I dont come on here much but if it isnt a sticky it should be, I just rewired my whole car and something like that with these scotch locked cars is valuable.
post #9 of 14 Old 05-23-2012, 04:39 PM Thread Starter
How can i make this a sticky post?
post #10 of 14 Old 05-23-2012, 04:45 PM
Talking
Right Click, then copy link.
post #11 of 14 Old 05-23-2012, 05:23 PM Thread Starter
ok then what lol
post #12 of 14 Old 05-23-2012, 05:41 PM
Question
How about you save it as a Favorite site?
post #13 of 14 Old 05-23-2012, 07:02 PM Thread Starter
lol i did that already
post #14 of 14 Old 05-26-2012, 04:04 PM Thread Starter
all fixed thank guys for the help....I put a MSD 6AL In all fixed
carb conversion redfox89 5.0/5.8 Engine Tech 6 11-11-2013 09:20 AM
For Sale Molding Inset Vinyl Stripe Tape - Red - for 87-93 GT Stangdawg Exterior Parts 0 05-15-2012 01:20 AM
For Sale Motorsport wire set 8.5mm, Red, only 500 miles on them 188slo50 Windsor Engine Parts 5 10-03-2011 07:35 PM
Adios old kitchen, it's been a fun-filled disgusting last 3 years. Dave88LX Lounge 258 05-05-2011 09:09 PM
