Occasional problem with driver window - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-20-2012, 09:43 PM Thread Starter
02PONY's Avatar
The other day I went to roll up my windows at work and the drivers side window wouldn't go up a few hrs later on my next break I tried again and it went up and down just fine. Now a few days later it is stuck down again but will not go back up. Any suggestions to fix would be appreciated
Sent from my Autoguide iPhone app
02PONY is offline
post #2 of 5 Old 05-21-2012, 12:39 AM
Sprayaway Fox's Avatar
You could go and take the panel out for the driver side window switch and see whats going on. Most likely the master switch panel on the driver size the contacts go out after a while which send power to the passenger side also I beleive.
When it doesnt work try using the passenger side to roll it up. If it doesnt work either its most likely the driver side thats bad.
Sprayaway Fox is offline
post #3 of 5 Old 05-21-2012, 10:46 PM
wmburns's Avatar
FWIIW, the Mustang's power windows are protected by an automatic reset circuit breaker in the engine bay and in the window motor itself. This explains why it doesn't work and then does.
If the CB is tripping, likely it's because the motor is drawing too much power. The most likely reason is worn bearings or the window is binding in the track.
Suggest starting by doing a functional test of the window motor directly from a power source. If the window works fine, this points to a wiring problem. Otherwise it's time for a new motor.
wmburns is offline
post #4 of 5 Old 05-22-2012, 12:42 AM Thread Starter
02PONY's Avatar
Well I took off the panel pushed the switch up and tapped motor and it works again so I'm gonna order a motor
02PONY is offline
post #5 of 5 Old 06-21-2012, 07:56 AM
something else that I found on mine was that the wire coating was being stripped by the door causing shorts. Two different spots on the wire and depending on where the wire was sitting it would or wouldn't work. The power window design on this car (if mine was not mutilated by previous owner) really baffles me. Take a look at the pic here and you can see where I taped one and then found another. Picture is from the passenger door looking towards the dash.
bravesman16 is offline
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
Rear pass window won't go up carpediem50 GT & SOHC 4 04-28-2011 12:19 PM
Rear pass window won't go up carpediem50 General Mustang Tech 1 04-22-2011 12:18 PM
Fuel Delivery Problem Solved!! Blown46Cobra GT & SOHC 9 12-18-2001 01:44 PM
my driverside window fell inside my door!!! speedfreak87 The Body Shop 4 12-13-2001 07:49 AM
