Passenger Window Wont Work... Need Help!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-18-2012, 10:29 PM Thread Starter
Nolan592's Avatar
So I've been putting this off and really need to get it fixed. My passenger window doesn't work. When I bought the car a few months ago it had wires hanging out from under the door panel and the guy told me if I touched a battery to on set it would roll up and if I touched the others it would roll down. As of right now I've changed the switches and put a new door harness in.
Here is what I've got. The drivers window will roll up and down just fine and the door lock works but it the drivers side won't operate the passenger side.
The passenger side will roll down now with the new harness but it won't roll up or operate the door locks.
What could my problem be? I am completely stumped.
Any help is GREATLY appreciated.
92 GT, Green/Grey, MM Control Arms, FMS B Springs, Bilstein HD Shocks & Struts, OEM 03/04 Cobra Brakes and Wheels
Nolan592 is offline
post #2 of 4 Old 05-19-2012, 12:11 AM
wmburns's Avatar
Disclaimer. I'm going to assume this is a 91 MY but my wiring diagrams are for the 92 MY.
Power for the passenger's side passes through the driver's side. Start by confirming +12 volts with the key on to both PK wires at the driver's switch.
Next confirm that all black wires on the driver's switch are in fact good grounds back to battery negative. The wiring diagrams show (4) black wires going back to a splice (S500) and then onto ground G500.
Do you have a set of wiring diagrams? If interested in getting a set for yourself, I maybe able to help. PM if interested.
wmburns is offline
post #3 of 4 Old 05-19-2012, 09:45 AM Thread Starter
Nolan592's Avatar
Yea sorry its on a 91 GT. So since I was able to jump those wires and the window would work that means its not a motor issue right?
Nolan592 is offline
post #4 of 4 Old 05-19-2012, 12:09 PM
wmburns's Avatar
Jumping which wires restored function?
The windows go up or down by reversing the DC current. Isn't it obvious that if the motor works at all, then the motor is OK? So if the motor works only in one direction then it has to be wiring related.
wmburns is offline
Electoral Issue – brake lights/turn signals do not work. V-Viper 94/95 Tech 5 07-15-2011 12:48 AM
Electoral Issue – brake lights/turn signals do not work. V-Viper Electrical & Wiring 0 07-13-2011 11:47 AM
Power window motor conflicting info /\Vader/\ General Mustang Tech 3 06-19-2011 10:42 PM
pics and a how to for getting an 03 cobra cluster to work in a 96 cobra 03sm3341 SVT & DOHC 1 05-27-2011 12:50 PM
my driverside window fell inside my door!!! speedfreak87 The Body Shop 4 12-13-2001 07:49 AM
