Speedo jumps - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-12-2012, 12:33 PM Thread Starter
Speedo jumps
Just put a used cluster in my 91 convertible and the speedometer won't stay still? Just a tad jumpy any tips?
kenworthkid28 is offline
post #2 of 2 Old 05-21-2012, 10:54 PM
wmburns's Avatar
I need some help to answer this. My Ford workshop manuals go back to 92 and I have nothing older. The wiring diagrams indicate the 92 uses a VSS speed sensor.
Does the 91 use a VSS sensor or a mechanical speedometer cable?
If the 91 uses a VSS sensor, then likely there is something wrong in the cluster electronics.
If mechanical, look for kinks and binding inside the cable. Common cause of a speedometer bouncing. Consider trying to lube the cable. Otherwise it's time for a new cable.
Here's some more links.
http://www.moddedmustangs.com/forums...ng-around.html
http://www.allfordmustangs.com/forum...ml#post2008659
wmburns is offline
Speedo jumping/bouncing/sticking erratically 94GTPilot 94/95 Tech 5 02-04-2012 12:54 PM
Speedo Gear Ratio, So Confused!! nomadtrash 94/95 Tech 5 05-16-2011 12:30 PM
Speedo problem 94gt orange50 94/95 Tech 0 03-21-2011 11:48 PM
Want To Trade nice 90 -93 140mph speedo, for 87 -89 140mph speedo ndmus88gteng Electronics and Entertainment 7 02-21-2011 11:12 PM
Help AOD Speedometer Recalibration SAS General Mustang Tech 13 12-28-2001 07:23 AM
