headlight switch problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-09-2012, 03:05 PM Thread Starter
the other day i was driving and my dash, taillights and hvac lights all went out but my headlights stayed on
figured it was my switch so i replaced that today
now it does the same thing as it did but if i slightly push the headlight button in my headlights go out and fogs,drl,tails,hvac and dash lights all come on but as soon as i pull it all the way out again they all go out other than the headlights
any help would be appreicated
thanks
nathan
98dropta is offline
post #2 of 5 Old 05-09-2012, 04:39 PM
Check the dimmer switch?
Megasquirt
seijirou is offline
post #3 of 5 Old 05-09-2012, 05:34 PM Thread Starter
dimmer switch works when pushed in barely past when the headlights come on.....even turns on the dome light....just cant get the headlights to stay on with the drl,fogs,dash hvac or vice versa....but when you first pull out the switch on the first click nothing comes on when the drls are supposed to...everything comes on except headlights just inbetween the first click and second click
98dropta is offline
post #4 of 5 Old 07-01-2012, 11:08 PM
Did you ever figure out what the problem was Im having the same issue with mine now.
blown1995gt is offline
post #5 of 5 Old 06-20-2015, 02:45 AM
Ok so I was installing raxiom sequential tail light kit in my 01 GT. the lights were working for a minute, but shortly after, one of the wires from my harness got burned up, and I could smell it, melted the wire. Now my tail lights, dash lights, and parking lots won't work. I've replaced the damaged wire, and I don't think that's part of the problem. Whenever I pull my headlight switch out barely past the parking lights spot (in b/t that and the head light spot) I get every one of my lights to come on as normal. I replaced the switch with a Duralast one from auto zone, and still have the same problem. Is the switch still my problem? Please help
cnasty36 is offline
headlight switch problem 98dropta SVT & DOHC 1 05-09-2012 11:41 PM
Random misfire problem? chargedWS6 5.0/5.8 Engine Tech 4 04-16-2012 04:39 AM
Need Help With Electric Problem woodwert General Mustang Tech 0 04-10-2012 06:34 PM
Sputtering while driving shiz1125 5.0/5.8 Engine Tech 16 04-03-2012 04:14 PM
Yet another Fox turn signal problem Kranium31 General Mustang Tech 20 05-28-2011 12:37 AM
