AirBag light flashing - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-24-2002, 08:57 AM Thread Starter
I just started hiding wire's in my engine bay (on the passanger side) by running them through the fender wall. Everything really cleaned up & I didn't cut any wire's, just unpluged them & relocated them behind the fender & plugged them back in from under the car. Well, now I have a flashing air bag light. Upon first start up, it will flash 5 time's, pause then flash 2 more. I took it up to Autozone to see what code it's throwing, but anything dealing with the air bag's, is a dealer only fix. Anyone ever have this happen? I would really like to find a fix, before I let the Ford dealer rape me on labor charge's. Thank's, Jake
JAKESSNAKE is offline
post #2 of 5 Old 07-24-2002, 09:52 AM
Anaconda's Avatar
Re: Air Bag light flashing?
Why is that a dealer only fix?
Have you disconnected the battery for a while to reset the computer?
Anaconda is offline
post #3 of 5 Old 07-24-2002, 10:18 AM Thread Starter
Good point (it's early)! When I unplugged all the wire harnesses & repluged them back together, I left the battery connected. I'm sure the comp. saw that, & that's why the code is popping up. I'll disconnect the battery today & let it sit for awhile. Thank's for the wake-up, I feel better knowing that's most likely the problem.
post #4 of 5 Old 07-24-2002, 10:24 AM
Steeda90GT's Avatar
You have a code 52 (Flash 5 times, pause then two times) from unplugging the battery, letting it sit WILL not cure it. You have to jump the wire under the glove box, let stangplus2birds explain it to you, I'm sure he'll be in here any minute now.
94 Oxford White GT. 18" Saleen wheels with BFG Drag Radials. Vortech S-Trim, etc. 89 Oxford White Notchback. Chrome Pony Wheels, Full exhaust, Pulleys, yadda yadda yadda, 94 GT Vert (Stockish cruiser)
Steeda90GT is offline
post #5 of 5 Old 07-25-2002, 02:13 AM
stangPlus2Birds's Avatar
Steeda90GT got it right.
YAWN!! It's 2am in the Northeast and I have to go to work tomorrow. I *try* to do a quick check every day for Air Bag and ABS questions.
See:
http://www.veryuseful.com/mustang/te...95.html#CODE52
http://www.veryuseful.com/mustang/te...agCodeClearing
Let me know if you have any questions.
Good night/ morning/ day whatever.
Joe - 86 Mustang GT with ABS!
M-2300K brakes, Mach1 Springs, D178 rims, and 245/45/17 RE730 tires. Car Pictures: http://www.veryuseful.com/mustang/tech/misc/Mustang1986_with_Mach1_springs/
stangPlus2Birds is offline
Upgrading from '89 to '93 dome light Shaker666 General Mustang Tech 2 05-21-2016 04:25 AM
Airbag light on solid. not blinking HELP ?!? Tesla1980 General Mustang Tech 7 04-08-2016 10:41 AM
Airbag light CanGT 94/95 Tech 2 08-30-2015 02:54 AM
Upgraded Dome light project? FoxfanLX General Mustang Tech 1 11-13-2011 02:13 AM
Flashing battery light 94CobraPace 94/95 Tech 2 01-10-2011 03:42 PM
