Crazy foxbody electrical problems!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 28 Old 05-06-2012, 01:14 PM Thread Starter
188slo50's Avatar
Exclamation Crazy foxbody electrical problems!!!
I have an 88 converted to MAF and this has me stumped on where to even begin looking. When I have the key on all my dash lghts turn on (like the headlights are on). . If the car is running the tach will go backwards/forwards and jump all over the place and the more rpms it gets the more it moves crazy. Ive pulled the dash to look for a wire grounding itself out but found nothing. I do have an MSD box but it seems to be hooked up fine unless its bad on the inside.
On another not I cant pull any codes and everyone says the computer is toast and its in a closed loop which is why it still runs. Is there any chance that one has to do with the other? The car has been driven since the mass air swap so Its not anything currently done to that but its been sitting for a probally 1.5 yrs due to a repaint and interior refresh. Any help would be great.
1988 GT- 306, AFR 165 , Peformer II, 4.10's, MAF conversion, 93 Cobra brakes, 315's, etc...
1999 GT 2v A/T.....4.10's, Cobra brakes,H&R, 315's.....SOLD
188slo50 is offline
post #2 of 28 Old 05-07-2012, 06:38 PM Thread Starter
188slo50's Avatar
anybody?
188slo50 is offline
post #3 of 28 Old 05-09-2012, 11:12 AM
mgt351's Avatar
Trader Feedback: (75)
Is it possible you have a cluster from the wrong year car 90-3?
14 F150 FX4 Screw
87 Mustang GT terminator swap
70 Torino GT 429 C6
93 LX Notch 333 glide 3.55
mgt351 is offline
post #4 of 28 Old 05-09-2012, 04:41 PM
That does sound like a toasted computer. Do you have any friends with a mustang that will let you try your computer in their car to see if the symptoms follow the computer?
Megasquirt
seijirou is offline
post #5 of 28 Old 05-09-2012, 04:47 PM Thread Starter
188slo50's Avatar
I have had a 92 in it for a good while and I switched back to the original 88 recently and then all of a sudden this.
188slo50 is offline
post #6 of 28 Old 05-09-2012, 04:48 PM Thread Starter
188slo50's Avatar
Yea goona try a new one but im thinking I got a short in the harness aswell cause I had a battery drain a while ago that fixed itself but never was able to find it before hand.
188slo50 is offline
post #7 of 28 Old 05-12-2012, 09:40 AM
indy2000's Avatar
when and how was it converted?
indy2000 is offline
post #8 of 28 Old 05-12-2012, 06:55 PM Thread Starter
188slo50's Avatar
Converted a like 2 yrs ago and did the harness with the pin swap and a A9l computer.
188slo50 is offline
post #9 of 28 Old 05-12-2012, 07:23 PM
indy2000's Avatar
original harnesses?
original 5spd car?
indy2000 is offline
post #10 of 28 Old 05-12-2012, 09:27 PM Thread Starter
188slo50's Avatar
Originally Posted by indy2000 View Post
original harnesses?
original 5spd car?
Yep all original to my knowledge and a factory V8 car.
188slo50 is offline
post #11 of 28 Old 05-13-2012, 12:33 AM
indy2000's Avatar
Was everything, correctly installed, ie vss, fuel pump monitor etc?
indy2000 is offline
post #12 of 28 Old 05-13-2012, 07:27 AM Thread Starter
188slo50's Avatar
Evrything was correct. I was driving the car for a while and now its been sitting and now this. Ive checked all the grounds and it all looks good I was thinking maybe a mouse chewed a wire or something but not sure.
188slo50 is offline
post #13 of 28 Old 05-13-2012, 09:12 AM
indy2000's Avatar
possible, do a visual on all the exposed wiring, check the ten pin connectors, and other plugs, these old plugs can have potential loose connections.
indy2000 is offline
post #14 of 28 Old 05-13-2012, 06:44 PM Thread Starter
188slo50's Avatar
Ok I did some looking today and pulled off all the grounds I could find grinded down the metal,cleaned terminal and reinstalled with no difference. I checked all the dash harness and the engine bay stuff that was moved to the fenderwell but dont see anything that stands on. I noticed today that only the right side of my dash lights light up when the key is on. Also noticed that if I flash my high beams the turn signal indicators come on and all the guages peg to the left. I still got to check the salt/pepper shaker plugs but doubt theres anything there. How can I rule out certain harnesses to narrow down the problem?
188slo50 is offline
post #15 of 28 Old 05-13-2012, 10:26 PM
indy2000's Avatar
I knew you could not change clusters that easily.
http://www.stangnet.com/tech/cluster87-93.pdf
I tried back in the mid 90s.
you will need to re-pin.
indy2000 is offline
post #16 of 28 Old 05-14-2012, 05:34 PM Thread Starter
188slo50's Avatar
I ran that 92 cluster for a while with no problems other than the check engine light not working. Now the 88 cluster is acting crazy. What damage could of been done from the 92 cluster that would now cause these problems?
188slo50 is offline
post #17 of 28 Old 05-14-2012, 07:54 PM
indy2000's Avatar
88 and 92 clusters are pinned differently.
without knowing the year of dash harness, who knows what went wrong.
indy2000 is offline
post #18 of 28 Old 05-14-2012, 09:04 PM Thread Starter
188slo50's Avatar
The dash harness is an 88. Do you think its possible thats what burnt up my computer?
188slo50 is offline
post #19 of 28 Old 05-14-2012, 09:33 PM
indy2000's Avatar
you should not be able to use the 92 in the 88 harness, unless it was re-pinned.
How do you account for the 92 cluster working as you say?
indy2000 is offline
post #20 of 28 Old 05-15-2012, 06:38 AM Thread Starter
188slo50's Avatar
All the guages worked from what I remember including the tach. The only other guage I use is the fuel guage cause I have autometer for everything else.
188slo50 is offline
post #21 of 28 Old 05-15-2012, 07:39 PM
indy2000's Avatar
then you do not have a 88 dash harness.
indy2000 is offline
post #22 of 28 Old 05-15-2012, 09:43 PM Thread Starter
188slo50's Avatar
I checked today with the wiring chart link you posted and its an 87-89 dash harness. Could of the cluster have been what burned up the computer? Im going to repin it and see if the cluster works this way.
188slo50 is offline
post #23 of 28 Old 05-16-2012, 12:25 AM
indy2000's Avatar
burn up the ecm, maybe
but what you say makes no sense
92 cluster with 88 dash works?
88 cluster with 88 dash doesn't?
indy2000 is offline
post #24 of 28 Old 05-16-2012, 06:34 AM Thread Starter
188slo50's Avatar
The 92 and 88 use to work did now neither one does anything right. Does the dash not working effect being able to pull codes since the curcuit isnt complete?
188slo50 is offline
post #25 of 28 Old 05-19-2012, 11:58 AM Thread Starter
188slo50's Avatar
Anybody know what to repin for a 4cyl cluster?
188slo50 is offline
post #26 of 28 Old 05-19-2012, 12:04 PM
mgt351's Avatar
4cyl cluster will work in place of a v8 assuming they are the same years. Tach will be off due to cyl count however.
Did you install the 92 cluster yourself or was it already in this car?
14 F150 FX4 Screw
70 Torino GT 429 C6
mgt351 is offline
post #27 of 28 Old 05-19-2012, 09:46 PM Thread Starter
188slo50's Avatar
Is there anyway to make the tach correct?
I installed it myself but like I stated I just plugged it in and used it. I must have a bad spot in my harness cause nothing works now. I dont have any turn signals but my 4 ways work when I hit the hazard button now also.
188slo50 is offline
post #28 of 28 Old 05-28-2012, 09:17 PM Thread Starter
188slo50's Avatar
Well I pulled the ECU harness today and founf no problems,breaks, or burnt wires so Imgoing to just put it back in. I got a dash harness coming so Ill try that and see if it fixes my problem. Im also going to try an find a 87-89 140mph cluster so I dont have to repin the harness. Im still confused on that one cause according to the schematic its different but 50% of the people out there said they just swaped them with no problems. Anybody got any Ideas of stuff that it could be that m overlooking?
188slo50 is offline
Electrical Problems Donovan 94/95 Tech 7 09-11-2011 10:35 AM
TC electrical problems update kd7cwg SVO/2.3L 3 08-28-2011 03:01 AM
power window electrical problems skeezer Electrical & Wiring 2 04-01-2011 06:28 PM
Starter and/or Electrical Problems. I need help. :) SkyRocketeer 5.0/5.8 Engine Tech 1 03-27-2011 01:39 PM
Arrrrrr! More electrical problems! Lisa GT & SOHC 11 06-05-2004 05:59 AM
