Alternator drawing amps with engine off - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-05-2012, 10:37 PM Thread Starter
dart408's Avatar
OK-
I recently re-clocked my 3g alt-
I have never started the engine yet, but had the key on to work on some other things. My hand touched the alternator pulley and noticed it was warm. Busted out the laser thermometer and sure enough it was 95* (65* day outside). Turned the key off for 10-15 mins, the pulley was room temp. I unplugged the alternator 3 wire plug, stator wire and sensing wire (batt in trunk sensing wire goes to charge pin). I installed a amp meter on the charge wire to battery and had zero amps with the key on or off. This tells me there is no amp draw from the battery. I then plugged the 3 wire connector and stator wire back in. Tested for amp draw on charge wire to battery with key on and off, again had zero amp draw from battery. As soon as i connected the sensing wire to the charge pin it pulled 5 amp with the key on and 0 with the engine off. Took the alternator to the parts store and it worked fine, also looked for charge wires to rectifier bridge and none of them are contacting the case.
Anyone see an alternator act like this? Thinking i f'd this thing up re-clocking it...
408 Dart, Fox Lake Vic Jr's, Proformance Racing TH400 , YSI, Holley Dominator EFI
dart408 is offline
post #2 of 5 Old 05-06-2012, 12:54 AM
460capri's Avatar
Trader Feedback: (48)
if the alternator is warm or very warm if not considered hot to the touch the alternator is bad . The guy at the part store did not test it correctly .
85 Capri 310 , 10.1cr , solid roller cam 608"/614"x 242*/248* AFR 205 heads , 1 3/4" headers , super victor intake , holley 750DP , MSd ignition system and NOS 150 shot .
460capri is offline
post #3 of 5 Old 05-06-2012, 01:15 PM Thread Starter
dart408's Avatar
check this thread out, interesting.
https://forums.corral.net/forums/5-0-...ngine-off.html
dart408 is offline
post #4 of 5 Old 05-06-2012, 04:05 PM
wmburns's Avatar
It might help to mention the model year and engine of the car in question. There are differences in how the charging circuits are wired between V6 and V8. As well as other differences over the years.
As others have said, the alternator does draw some power as long as the key is on. The battery is used to power the alternator's field coil.
The important thing is for the power draw to be zero with the key off.
If the alternator is drawing current with the key OFF, could the "A" and "I" terminals be reversed? This would have the effect of turning on the alternator all of the time for a late model Mustang 96+
wmburns is offline
post #5 of 5 Old 05-06-2012, 04:12 PM Thread Starter
dart408's Avatar
opps sorry
91 with a 3g alt -351w
battery in trunk
yellow "sensing wire" connected to charging pin on back of alt
green wire to oem ford green wire-12v+ when key on
white wire goes to stator
dart408 is offline
Help Wanted! PLEASE Read. (BLOWER CAMS) MARK 302 Superchargers 53 02-24-2012 09:51 PM
Cobra GT40 engine vs. Ford crate 302??? 93blucoupe 5.0/5.8 Engine Tech 9 02-22-2012 10:37 PM
For Sale FEELER: 4.6l 4v Complete Engine BlownMike Modular Engine Parts 8 03-07-2011 02:47 PM
Engine miss and KOER codes, help (long) Lars Pedersen 5.0/5.8 Engine Tech 7 01-12-2002 12:41 AM
Official Mod Motor 2vna rules Dave King GT & SOHC 37 12-21-2001 01:27 PM
