testing for continuity, oil press wire at gauge??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-05-2012, 10:08 PM Thread Starter
my 88 has a non working oil press gauge. to check wiring i grounded the wire and it should have pegged but it didnt so it must have a break somewhere.
i checked the wire for breaks under the hood and the wire was broken at the valve cover so i reconnected it but still no worky so it must have another break somewhere.
pulled the cluster and checked the whole plug and 4 wires are positive for continuity.......??
does one wire control the gauge or is it broken up into multiples from the ecu to cluster?
EDIT:
got an alldata print out and it says only 1 wire controls the gauge. the white w/red stripe. so i have the dash all torn apart, center console and all that but can't find anything that looks like its messed up/tapped in/grounded or anything.......yet.
the only thing i can think is to find out which side of the firewall it comes through and remove the stock tape and wire loom from there to the cluster plug??
s_blazin is offline
post #2 of 7 Old 05-12-2012, 09:43 AM
indy2000's Avatar
try Mustang FAQ - Wiring & Engine Info for free diagrams
indy2000 is online now
post #3 of 7 Old 05-12-2012, 07:30 PM Thread Starter
thank you for that link. its helpful but i was hoping someone had taken a harness out of the car before and could tell me where that wire routes exactly.
im not taking anything else apart, that would ensue the dash being removed the harness tore apart to find this thing and im not doing that
s_blazin is offline
post #4 of 7 Old 05-13-2012, 12:35 AM
indy2000's Avatar
its part of the engine harness, the connects to dash harness.
you have two plugs by the left strut tower that connects the dash to engine harness.
post #5 of 7 Old 05-13-2012, 10:00 PM Thread Starter
i disassembled the engine harness right after posting yesterday. traced the wire from the sender all the way to where it enters the fire wall and it was good no breaks and had continuity. unless i pulled the dash and column i couldnt get to the harness from the firewall to the fuse box to check that area. i worked and worked and finally got fed up with it and just put everything back together.
i hate leaving it not working but it was just giving me to much frustration
s_blazin is offline
post #6 of 7 Old 05-13-2012, 10:30 PM
indy2000's Avatar
you only half diagnosed
do you have conintuity from one end to the other?
post #7 of 7 Old 05-23-2012, 10:51 PM
You need to load test the wire, it will tell you if the wire is good. It can have continuity but have bad spot in wire. Use a headlamp bulb to load test.
Hurricane91 is offline
For Sale Autometer Gauges - Elec Oil, Water, Volt and Mech Fuel Press with Isolator EvinH Interior Parts 14 01-23-2012 08:21 AM
For Sale 2 5/8 Autometer Oil Pressure Gauge 04lvl2 Interior Parts 2 12-21-2011 07:56 PM
For Sale Autometer phantom tach and oil presure gauge mdbstang Electronics and Entertainment 2 12-01-2011 01:38 PM
For Sale Brand New Never Opened 2 5/8 Autometer Electric Oil Pressure Gauge (Part # 4453) Drake05 Electronics and Entertainment 0 04-25-2011 02:19 PM
Wild oil pressure gauge Smackee 5.0/5.8 Engine Tech 2 12-28-2001 01:15 PM
