94 GT - Where are the courtesy/door pin switch light wires? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-01-2012, 10:22 PM Thread Starter
Arrow 94 GT - Where are the courtesy/door pin switch light wires?
I bought some LED footwell lights and I would like for them to turn on when the doors open and turn off when they close. There are just 2 wires, +/-. The directions say "you will need to locate and connect to the correct wires for courtesy lights or door pin switch nearby the fuse box under the dash".
Does anyone know where I would find these on a 94 GT? And/or how will I know them when I see them?
Thanks in advance!
mattmathis is offline
post #2 of 2 Old 05-05-2012, 12:18 PM
wmburns's Avatar
Convertible or coupe? Remote key-less entry? Anti-theft?
Do you want the LED to come on when either door is opened or just the driver's?
Where do you plan to mount them?
Likely the easiest place to tap this is the GY wire at the head light dimmer circuit. Test for +12 volts with the door open. Voltage should go away when the door is closed.
A full set of wiring diagrams may offer some help. Are you interested in getting a set for yourself?
wmburns is offline
Want To Buy 94-98 fog light switch PIGTAIL BOOM_FIST Interior Parts 6 02-24-2012 12:15 PM
I need the part # for the MSD window switch for a 99+ GT 89FOX GT & SOHC 2 12-17-2001 03:47 PM
NEED HELP w/ brake light switch on brake pedal assembly???? The Man 5.0/5.8 Engine Tech 2 12-16-2001 04:31 AM
Fog light switch is burned out. Pottus GT & SOHC 5 11-26-2001 11:48 PM
