DAMAGED IGNTION Switch Connector wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-29-2012, 12:55 PM Thread Starter
Pushrods's Avatar
Exclamation DAMAGED IGNTION Switch Connector wiring
How to repair? Two issues...
1. One of the heavier gauge wires is totally severed and dosen't have enough length to conventionally splice, or repair. Would it be safe to splice in a totally seperate wire of the same gauge to each end, so I have enough lenght?
2. There are also two wires that have the entire circumference of the insulation stipped for about 1/4 inch section. This was done so some IDIOT could tap into the circut for power. Not malicious, etc.
How to repair those? Cut, resolder, and heat shrink? ORRRR, could I just use some PERMATEX "liquid electical tape" and fill in the gap areound the completely exposed copper? The copper strands themselves do not appear to be damaged alt all.
I was hoping the permatex solution would work, and I am very nervous about adding an additional length of wire to gain the necessary length...I don't really see any other options other than buying a new harness/ of a repair kit if I can find one....
Thanks in advance.
1994 Mustang Cobra. Stock drivetrain, Hooker Super Comp.'s, catless 2.5 x pipe, Flowmaster 40's dumped before axle. Smog and AC deleted, Eibach springs.
Pushrods is offline
post #2 of 2 Old 04-29-2012, 04:09 PM
Liquid tape is fine. Extending the wire is also fine. Solder your connections.
Megasquirt
seijirou is offline
For Sale Custom Nitrous switch panel for 01-04 Mustang stumbaugh Power Adders 4 10-26-2011 10:34 AM
For Sale MSD window switch (8956), Autometer RPM switch (5310), MSD/Vortech BTM carbd86gt Electronics and Entertainment 9 07-21-2011 12:53 PM
Clutch safety switch, adding push button switch into it.... black93 General Mustang Tech 2 01-30-2011 12:10 AM
Thinking about a window switch gtcobra302 Nitrous 2 12-15-2010 08:06 PM
