Cable routing - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-16-2012, 06:22 PM Thread Starter
Cable routing
How do you guys route your cables from a trunk mounted battery to the front? Do you go earth to the block then to a bus bar? And does the power go straight to the bus bar then to the starter?
Any help and pics would be good
1970 Mach 1 Mustang with SoT bilsteins and mid-eye 4 1/2 leafs 620lb drop springs in the front. *393 4V cleveland with Buddy Rawls custom solid cam Astro A5*
Reverb is offline
post #2 of 3 Old 04-23-2012, 01:39 PM
I bolt the ground from the battery to the rear frame rail. And bolt the engine block to the front frame rail. Clean off all the paint before adding the bolts and then hit them with rubberized undercoating after installation to keep rust away.
The positive cable runs through the car under the carpet up to the starter solenoid on the fender.
Megasquirt
seijirou is offline
post #3 of 3 Old 05-06-2012, 08:37 PM
todd95GT's Avatar
I ran power, ground, alternate feed (one wire alternator) up through the car to firewall feed-through style junctions. This gave me a great direct ground source. I put the connections high enough that a passenger's feet won't kick them.
Todd
87 coupe | 408W
Verde Ithaca Mica (Lamborghini Pearl Green)
@lambogreenLX on Facebook and Instagram
todd95GT is offline
Clutch Cable Routing problem spoonep3 Turbochargers 20 06-26-2013 08:16 AM
Factory 4R70W Shift Cable Bracket Work With Supplied Hurst Quater Stick Cable? Meangrn92GT General Mustang Tech 1 02-17-2012 10:24 AM
For Sale Steeda Adustable Clutch Cable - NIB tdmcree Drivetrain Parts 2 01-05-2012 09:17 PM
Put a 94-04 clutch cable in my fox. 289stang General Mustang Tech 0 06-28-2011 01:01 AM
How many of you are still Cable TV subscribers? Cobra Jet NJ Lounge 35 12-09-2010 09:18 PM
