Fox Electrical - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 04-10-2012, 10:35 PM Thread Starter
Fox Electrical
Greetings. Have a 1993 Fox Convertible. While stopped at a redlight today, the car suddenly died. Was not able to crank or have any electrical accessories work. Luckily I was able to push the car out of traffic. After sitting for a few minutes, I was able to start the car. I did notice something peculiar this morning before the car died. Turn signals would not work with the engine running but would work with the engine off key on. Any ideas where to start looking as I dont wish to be caught off guard. Thanks in advance.
palacios289 is offline
post #2 of 7 Old 04-11-2012, 12:08 AM Thread Starter
Just went outside to the car. The following DO NOT work with the engine running. Turn signals, HVAC and convertible top. They do work with engine off key on. Ugh! any ideas?
post #3 of 7 Old 04-11-2012, 01:16 AM
Possibly the ignition switch on the bottom of the steering column
Sent from my SAMSUNG-SGH-I777 using Tapatalk
95 GT Back from the dead. 342 stroker with 190 Trick Flow heads and intake and the other usual bolt ons with TR3650 transmission
Pfirmin is offline
post #4 of 7 Old 04-11-2012, 01:39 AM Thread Starter
anyway of testing it?
post #5 of 7 Old 04-11-2012, 02:57 AM
That's gonna require help from someone else. Its been a loonnnggg time since I dealt with one.
Pfirmin is offline
post #6 of 7 Old 04-11-2012, 07:13 AM
kiser312's Avatar
Take the plasctic surround off of the column. There will be a connector on the bottom of the column with 10 wires or so that is long and slim. Make sure that there is no play in that connector. It is a connector that rides upon each other ever time you start the car. I had to zip tie mine until i could order a new one from Late model Restro. If the car has tilt wheel try moving the wheel up and down and see if you gain turn signals.
kiser312 is offline
post #7 of 7 Old 04-11-2012, 08:55 AM
Here's a step by step with pictures:
Replace a 1979-1993 Ignition Switch Assembly
A Faulty Ignition Switch Can Create a Myriad of Electrical Problems
From the March, 2000 issue of Mustang Monthly
By Mark Houlahan
Photography by Michael Johnson
Read more: Replace a 1979-1993 Ignition Switch Assembly
John
'92 SSP (ex-FHP 797) stock - SOLD
jmbaltz is offline
Fox Body throttle body to 94-95 throttle body swap Z95m6 5.0/5.8 Engine Tech 2 09-26-2014 07:23 AM
Home Electrical Question Paully's5.0 Lounge 0 12-28-2013 05:36 PM
For Sale Fox & Sn95 parts. Stock & Performance jandmmustangs Miscellaneous Mustang Parts 7 12-15-2012 10:29 AM
For Sale garage cleanout 351w/302, fox parts fsstnotch Windsor Engine Parts 23 09-19-2012 11:09 AM
Electric Fan Upgrade with Stock Fox Electrical System 5.0PEV General Mustang Tech 2 04-28-2011 01:05 AM
