Need advise - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-10-2012, 08:42 PM Thread Starter
Need advise
I am trying to figure out how to keep my 87 headlight harness but make it work with foureye headlights. So far the only thing I have come up with is to order a pair of unsealed 4x6 headlights that accept h4 bulbs and splice them into my existing two way lights. Just not sure if the 87 harness is compatiable with the halogen bulbs. They are both a two way bulb just not sure if they will plug right into my existing plugs or will I have to cut my plugs off and wire them to the h4 plugs. The reason for this is that I can't find a good 85 harness to swap for my 87 and I also would like to leave out the two inner lights to use them as a airduct to feed my turbo. So I will need the two outer lights to be two way bulbs ( high and low beam). Does anyone have any experience with these lights and will they work with my 87 harness? Thanks
86 gt ,Proline built 352, ysi, built AOD, Fast fuel management. 550whp at 15psi and no timing.
85novi2k342 is offline
post #2 of 2 Old 04-23-2012, 02:55 PM
You'll need to splice in the new sockets for the sealed beam headlights, but that's it. It's very straightforward and shouldn't take you very long to do, even the colors match up.
Megasquirt
seijirou is offline
Need advise for my 4v mark viii swap and drivetrain questions swapd2002gt SVT & DOHC 29 09-11-2013 06:01 PM
Feels like a fuel cut between shifts-need advise Floordford GT & SOHC 19 11-06-2011 07:25 PM
Going manual brake on fox, any advise? pwrdbypsi General Mustang Tech 0 04-25-2011 08:25 AM
1993 Cobra build advise mustangnumber6 5.0/5.8 Engine Tech 6 04-04-2011 10:22 PM
New to fox chassis, need help fitting tires and other advise SLOW5.0 Wheels and Tires 1 12-19-2001 06:23 PM
