Master Cutoff Switch Question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-27-2012, 07:29 PM Thread Starter
Okay Gents, I've done more searching than I'd care to do again to find the answer I'm looking for. I have a Vortech kit I'm installing on my 96 cobra with a trunk mounted battery. I know how I'd like to wire the car but am unsure of one thing revolving around the master cutoff switch required to track it. Below is a diagram I've found and am basing my wiring off of. The issue I'm running into is whether or not a Painless wiring Alternator Shutdown Relay is really necessary. I guess I don't see the point of it and am hoping someone has experience in this and can chime in. From what I've heard others say, it is required to prevent a voltage spike that could fry the ECM when the cutoff switch in engage. It is also used to prevent engine run on. The way I'm wiring the car puts the underhood junction block on the disconnected side of the battery thus killing all electrical in the car. So if anyone could shed some light on something that I'm missing or confirm that I'm heading in the right direction, I'd greatly appreciate it.
Sorry for the novel.
white96svt is offline
post #2 of 3 Old 03-28-2012, 12:05 AM Thread Starter
Anyone????
post #3 of 3 Old 06-10-2012, 10:35 PM
bluebandit's Avatar
That would work... but it would leave power to your alt, and it would leave the battery light on your cluster. which will drain the battery.. I have the same basic set up right now. I am buying a Sparco battery kill switch. this cuts down about 20 lbs of wiring. its worth the 60 bucks if you can wire it right.
bluebandit is offline
Tremec 3550 TKO 500 & 600 Backup Light Switch PSA Cougar5.O General Mustang Tech 16 06-04-2012 06:09 PM
Magical Disappearing Brakes - 1992 Mustang Lifted94XLT General Mustang Tech 84 03-03-2012 01:43 AM
For Sale 1990 Convertible top switch and window 351turbo Miscellaneous Mustang Parts 0 03-29-2011 09:37 PM
Manual Cooling Fan Switch mudanoman GT & SOHC 1 12-12-2001 01:15 AM
Fuel Pump cutoff switch diagram marty General Mustang Tech 2 11-29-2001 12:14 PM
