Flex-A-Lite VSC 31165 - How to wire 'fan on' indicator light? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 03-23-2012, 09:45 AM Thread Starter
Greetings,
I'm in the middle of putting a 3.8L Taurus fan on my '91 with a Flex-A-Lite VSC. I had a 'Black Magic' before.
On the Black Magic, I was able to splice into the +12V to the fan and power a small light in the car to tell me when the fan was on. With the VSC, instead of switched power, ground is switched. So, the fan wires are both hot when the fan is off. I figured all I would have to do is put power to the light in the car (instead of ground) and then use the switched ground on the controller to turn complete the circuit and turn it on.
Well, when I switch on the fan, the light comes on bright then dims and goes out as the fan comes up to full speed. The voltage in the switched ground to the fan is 0 but the bulb still goes out.
Has anyone else tried to put a 'fan on' indicator light w/ a VSC?
Does anyone know their electrical theory well enough to tell me what is going on and how to make this work (diode in line, etc)?
THANKS!
'03 Mercury Marauder, '91 Ford Mustang GT Convertible, '69 For Mustang Sportsroof, '77 Pontiac Grand Prix, '32 American Austin, '02 Fleetwood Storm motorhome (F53 w/ V10)
neo102470 is offline
For Sale Flex A Lite 410 Dual Fan - 2 5/8" Thick *NEW* NOStang89 Windsor Engine Parts 0 08-16-2011 11:59 AM
Blowing fuses, flex a lite 33504 variable speed fan control bolt-on-bandito General Mustang Tech 6 07-01-2011 01:44 PM
Fan clutch engagement oatburner99 5.0/5.8 Engine Tech 9 06-17-2011 05:03 PM
For Sale Flex a lite electric fan (black magic) Blown302stng Electronics and Entertainment 1 05-27-2011 10:01 AM
For Sale Flex a lite black magic electric fan onefiine69 Electronics and Entertainment 9 01-19-2011 06:26 PM
