Fuel Gauge Problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-22-2012, 08:32 AM Thread Starter
86montesbc's Avatar
Fuel Gauge Problem
I have a 90 5.o LX my fuel gauge only works around the red empty mark if there is two gallons or more it reads slightly above a empty between red and the first notch and when it is just about empty it goes below the red line.. i replaced the sender and found it to be the same problem my power at the sender is only 3.7 volts any ideas? has anyone else had this problem? any help is much appreciated
86montesbc is offline
post #2 of 2 Old 03-23-2012, 08:56 PM
87coupe50's Avatar
Trader Feedback: (25)
maybe this will help
Originally Posted by 87coupe50 View Post
my understanding is that if you disconnect the harness at the sending unit and the gauge reads full then your sending unit is the problem, if the gauge doesn't move then its your anti slosh module.
My gauge wouldnt move at all, TODAY I tried to replace the sending unit and it still didn't work (before I found out about this trouble-shooting method). I found a couple anti-slosh modules at the junk yard (where I also found out there was a difference between 87-89 and 90-93), replaced it with a matching module and my gauge now works. There is also a write-up about swapping the large resistor (100 micro farad 25v) with one from radio shack.
'87 Notch: Coyote swap 10.69 @127 w/ 1.47 60' SOLD
'89 Notch: Coyote Swap 10.03 w/1.33 60' Outlaw
'93 Notch: F150 Coyote swap SOLD
'82 Notch: F150 Coyote swap
87coupe50 is offline
CCRM/FPDM Problem - No Fuel After Cam Swap Tombstone02 GT & SOHC 3 11-24-2011 09:33 AM
Fuel Gauge on FPR Drops 5lbs when Vac Off ebx 5.0/5.8 Engine Tech 4 06-05-2011 02:13 PM
Intermittent Fuel problem help PurePony S-197 Mustang (2005-2010) 4 12-11-2010 05:08 AM
