what plug and harness is this 91 4 banger coupe - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 03-21-2012, 01:49 PM Thread Starter
stangonlaughngas's Avatar
The smaller plug is to the washer fluid pump. what is the orange plug and the black plug?
Can I follow this back to the fuse panel and cut them out?
stangonlaughngas is offline
post #2 of 8 Old 03-22-2012, 07:47 AM Thread Starter
TTT
post #3 of 8 Old 03-24-2012, 08:13 AM
it looks to be the same as mine and its just a dead end but i wouldnt cut it. i just tucked mine inside the fenderwell
honda1wheel is offline
post #4 of 8 Old 03-24-2012, 10:43 AM
1BAD6T6's Avatar
I'm redoing my wiring on mine as well and have run across it. I pulled the cap and found that a few of the terminals are connected by pins inside the cap. Since my harness is completely exposed, I'm tracing it out as I write to determine whether or not I can cut it out.
1966 Mustang Coupe
1993 Coupe - LM7, pt88, th400, MS3x
1995 GT - 100% Stock (emissions and all)
1BAD6T6 is offline
post #5 of 8 Old 03-24-2012, 05:30 PM
1BAD6T6's Avatar
The orange plug in the upper right of your pic is difficult to see, but it goes to your gauges and contains a switched 12v to your igntion system. Keep it. Brown Connector Also, I traced out the black one. I ended up leaving it b/c the wires ran to all sorts of stuff, ignition switch, gauges, etc. Looks to be an overall PITA to deal with.
1966 Mustang Coupe
1BAD6T6 is offline
post #6 of 8 Old 03-25-2012, 01:36 AM
The large oval connector with the shorting plug is for the DRLs used on Canadian models.
Saleen0679 is offline
post #7 of 8 Old 03-25-2012, 09:06 AM
1BAD6T6's Avatar
DRLs???
1966 Mustang Coupe
1BAD6T6 is offline
post #8 of 8 Old 03-25-2012, 11:19 AM Thread Starter
Day time run lights
