Wire up wideband o2 plx-m300 to replace factory o2? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-20-2012, 10:59 PM Thread Starter
jruppert's Avatar
I've had this plx-m300 wideband for probably 6 years now and have had an extra bung installed and had the wideband wired up to the EGR for my tweecer. I will be replacing my h-pipe for an x-pipe and I thought about replacing a factory o2 with the wideband. It seems to me at one time I read online that you can use the wideband instead of an narrowband o2 and that you would route some wiring to the harness for the factor o2. Is this correct? Has anyone done this? It seemed like the article that I read claimed it was more accurate than using a narrowband. So has anyone done this? Thanks in advance
1987 Mustang GT Convertible, 5 speed
SOLD - 94 GT 351w, AFR 185's, TFS cam, 30lb injectors, Edelbrock RPM, Pro-M 77mm, 1.7 rr, Steeda radiator, Tremec TKO, 3.73 gears, Tweecer RT
jruppert is offline
post #2 of 6 Old 03-23-2012, 11:27 PM
indy2000's Avatar
need an emulator.
narrow bands are more accurate.
indy2000 is online now
post #3 of 6 Old 03-24-2012, 01:03 AM Thread Starter
jruppert's Avatar
What is an emulator? I have the wideband o2 and the box that displays the info also the tweecer. I have heard in past that the wideband is more accurate. Maybe I am hearing conflicting information.
jruppert is offline
post #4 of 6 Old 03-24-2012, 09:12 AM
indy2000's Avatar
emulator takes the 0-5v input from the WB converts it to a 0-1v NB output that the eec can use.
Lab grade WB are more accurate, but the consumer level one that we use is not near the accuracy of the Lab grade.$$$$$
post #5 of 6 Old 03-24-2012, 09:20 AM Thread Starter
jruppert's Avatar
I do know that my wideband has a narrowband wire coming from it. But I am really not sure. I suppose I can just keep doing what I have been doing.
jruppert is offline
post #6 of 6 Old 03-24-2012, 09:55 AM
indy2000's Avatar
run both, by adding a bung.
when you have it running like you want, remove the WB, plug the bung.
I don't use a WB guage, I only use it for tuning purposes.
For Sale New PLX LED Gauges and Sensors Turbo98 Interior Parts 5 02-03-2012 09:51 PM
For Sale NIB PLX M300 Wideband... qikgts Electronics and Entertainment 8 01-26-2012 11:03 PM
Adios old kitchen, it's been a fun-filled disgusting last 3 years. Dave88LX Lounge 258 05-05-2011 09:09 PM
