Burnt computer from not running a transmission wiring harness - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-13-2012, 12:44 AM Thread Starter
I have a 92 coupe that started life as a 4 banger auto, it now has a 5.0 with a tremec 3550 and a9l computer.
My question is, will my computer fry if i don't run a transmission harness at all?
I just put a push button start in and drove it like that for about 6 months it ran fine but, does have hot start issues i cured that by hooking a toggle switch up to turn the fuel pump off until it fires up, then i flip the pump on. However it does blow the fuel pump relay sometimes.
Recently the car runs like crap don't idle right, runs real rich, and if i floor it or give it more than half peddle it falls on its face, would this be signs of a burnt sigrtn trace in the computer?
I did order a 5 speed trans harness off ebay today so i will hook it up but, is it to late for my computer?
Oh I forgot to mention that i DID rewire the 02 harness to a 92 5 speed before i ever started it.
GTforME is offline
post #2 of 5 Old 03-14-2012, 08:06 PM Thread Starter
NO ONE??????????????
GTforME is offline
post #3 of 5 Old 03-15-2012, 09:28 PM
87coupe50's Avatar
Trader Feedback: (25)
post is kinda confusing... how long ago did you swap to a TKO?
shouldn't be anything more in the wiring harness then the reverse lights and VSS. There is no electronic control of the trans. Lack of VSS could be giving you some issues but that should be more towards driveability.
'87 Notch: Coyote swap 10.69 @127 w/ 1.47 60' SOLD
'89 Notch: Coyote Swap 10.03 w/1.33 60' Outlaw
'93 Notch: F150 Coyote swap SOLD
'82 Notch: F150 Coyote swap
87coupe50 is offline
post #4 of 5 Old 04-22-2012, 10:36 AM
An82Mustang's Avatar
I agree... There is no huge difference between a 5 speed and an auto ECM harness.... And the tranny harness just has a NDS switch and backup lights in it. (The VSS is in the body harness and comes from the tranny tunnel...)
88 Sonic blue coupe...-
RIP
89 GT Convertible - Sold it!
2000 Kona Blue GT Convertible 4V
2005 Sonic Blue GT
An82Mustang is offline
post #5 of 5 Old 04-23-2012, 01:34 PM
Pull codes and see if the computer is complaining about anything.
If you don't have any kind of burnt electronics smell the ecu is probably fine.
Megasquirt
seijirou is offline
For Sale 1996-1998 auto transmission wiring harness for 4.6L keithnra Electronics and Entertainment 4 02-12-2012 07:44 AM
For Sale 1st Gen PIH harness (Fox to 94/95 adapter) and A9M computer SilverSmith82 Electronics and Entertainment 6 10-05-2011 03:17 PM
For Sale A3M MAF Computer and Wiring Harness Josh93 Electronics and Entertainment 3 07-22-2011 01:11 AM
For Sale 1989 Mass Air Wiring Harness and A9L Computer With Injector Harness 350.00 P/S mustangt66 Electronics and Entertainment 1 12-20-2010 11:33 AM
