1988 5.0 wont start with key - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-12-2012, 08:00 PM Thread Starter
I did A few upgrades on my car , and cleaned up some wiring under the dash. I I alspo moved the battery to the rear of the car. After all done I went to turn the key everything in the car came on but would not start no clicking or anything. It will start jumping out the stqarter solenoid, I changed the solenoid still nothing, changed the igition switch and still nothing. I Dont know where to look next. some help please.....
oneslowsaleen is offline
post #2 of 5 Old 03-12-2012, 09:00 PM
Check to see if your inertia switch in the trunk or hatch (behind plastic panel near DS tail light) is tripped or bad. Make sure you have power in and out of both wires or its bad.
make sure your neutral safety switch is still hooked up. since you messed with some wiring maybe you accidentally unhooked it.
Frankenstang2120 is offline
post #3 of 5 Old 03-12-2012, 09:56 PM Thread Starter
i checked the nuetral safety switch , even tried bypassing it to see if that was the problem. My fuel pump turns on so i know the relay in the back of the car isnt tripped. I am clueless
post #4 of 5 Old 03-12-2012, 11:59 PM
Well I would say chase the red wire that goes from the top of the starter solenoid. make sure it isnt broken anywhere. Ive seen a ton of those that just get thrashed by age.
post #5 of 5 Old 03-17-2012, 10:23 AM
indy2000's Avatar
you did something to the clutch sensing switch.
you said you jumped it, did you verify power to the red trigger wire on the solenoid?
indy2000 is offline
For Sale 1988 Ford Mustang 5.0 LX Hatchback "Virgin" tubbedamx Mustangs For Sale/Wanted, 1987-1993 5 09-05-2011 09:37 AM
For Sale 1988 5.0 5 speed Ranger roller frankstang88 Other Fords and Trades 0 03-11-2011 03:43 AM
For Sale 1988 COUPE 5.0 5SPEED SUPERCHARGED $5900 cwc Mustangs For Sale/Wanted, 1987-1993 2 02-22-2011 06:34 PM
