Fuel pump relay problem... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-12-2012, 07:58 PM Thread Starter
Toll Road's Avatar
1993 mustang original 5.0 car. Car has a 255lph Walbro fuel pump. Just recently I went to start the car....and the fuel pump ( that usually turns on for a second) well the pump stayed on the whole time the key was in the on position. I try to start the engine..and it just turns over..doesn't fire. I replace the fuel pump relay and it fires right up. Normal fuel pump kicks on for a second everything is fine.
I drive the car a few times...2-4. And the same thing happens again. Go to start it and the fuel pump stays on and car wont start...but turns over.
I'm getting another fuel pump relay tomorrow.
I noticed my gas level both times this happened has been real low, around an 1/8th tank to a little less. Could my fuel pump be getting too hot and eating up my relay?
Any thoughts or suggestions I would greatly appreciate. Thank you.
pfo mustang member
xXx Motorsports. Pensacola FL.
Toll Road is offline
post #2 of 5 Old 03-12-2012, 10:38 PM Thread Starter
Toll Road's Avatar
pfo mustang member
post #3 of 5 Old 08-29-2012, 11:34 PM
Did you ever figure out the problem? I'm having the same issue....
MFT
DreadFox is offline
post #4 of 5 Old 09-06-2012, 04:36 PM
I've seen this happen when the computer has a problem.
Megasquirt
seijirou is offline
post #5 of 5 Old 09-10-2012, 11:13 PM
fivepointwoahhh's Avatar
I've had this problem & it ended up being the fuel pump relay that was bad. Replaced it & it works great with no issues!
fivepointwoahhh is offline
For Sale Aeromotive 18601 Sumped 79-98 Fuel Tank $450 shipped StangTV.com Fuel System & Related 2 10-01-2011 01:57 AM
FUEL PUMP PROBLEM 95 GT??? BruceBlueStang 94/95 Tech 1 07-22-2011 09:31 PM
HELP PLEASE I need the part number for my fuel pump relay!!! 92interceptor 5.0/5.8 Engine Tech 3 01-13-2002 11:38 AM
