need help with wiring VSS into a '87 non C/C - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-12-2012, 12:48 PM Thread Starter
87coupe50's Avatar
Trader Feedback: (25)
I've read several threads on the subject and they mention about splicing into the Org/Yel and Grn/Wht wires on the 8 pin connector, located behind the driver kick panel. I found this connector yesterday and both wires are present but they go back into the wiring harness, I have no wires continuing on down to the where the VSS sensor would be (I currently don't have a sensor connector). I also pulled my computer out and checked to see if those same wires were connected to the computer at positions #3 and #6; nothing is connected to those positions.
Does this mean I would have to get a sensor and run the wires directly to the computer and connect to pins #3 and # 6? If so, does anyone know where to get and what type of pin connectors I would need to get in order to pin into the computer harness connector?
FYI... I'm wanting to wire one in because the VSS sensor will allow me to datalog MPH and gear position with the Moates QH. And I do get the occasional stall when coming to a stop (now that I switched to an auto trans).
'87 Notch: Coyote swap 10.69 @127 w/ 1.47 60' SOLD
'89 Notch: Coyote Swap 10.03 w/1.33 60' Outlaw
'93 Notch: F150 Coyote swap SOLD
'82 Notch: F150 Coyote swap
87coupe50 is offline
post #2 of 5 Old 03-17-2012, 10:16 AM
indy2000's Avatar
88 CA and 89+ dash harness has the connectivity for VSS to ECM harness.
If you are using a 87 dash harness it will not work.
you will need to add the wires from the VSS to the ECM inputs.
This is the same for fuel pump monitoring circuit.
indy2000 is offline
post #3 of 5 Old 03-23-2012, 09:21 PM Thread Starter
87coupe50's Avatar
I found a vss sensor connector and got the computer pins and wires from a junk harness. I think I gotta get a C/C speedo cable now in order to fit into the VSS sensor.
post #4 of 5 Old 03-25-2012, 09:05 PM Thread Starter
87coupe50's Avatar
got it all wired in and works like a champ! At first I forgot I disabled the VSS switch in the tune, worried me when it didn't work. I did have to get a C/C speedo cable so the end would fit in the VSS sensor.
post #5 of 5 Old 03-25-2012, 09:34 PM
indy2000's Avatar
nicely done.
indy2000 is offline
dreaded wiring harness issues... Networktec Electrical & Wiring 18 05-07-2012 02:11 AM
For Sale DetailZone wiring and ECU for dohc4.6 teach4.6 Modular Engine Parts 3 09-05-2011 12:51 PM
Changing the hatch wiring from 1989 to 1992 sozzyber General Mustang Tech 3 04-24-2011 09:32 PM
Does stock 87-93 mustangs come with single stage paint from the factory? fiveohfanatic The Body Shop 5 01-08-2011 10:07 AM
