WONT START! Out of ideas!!! Please help! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-12-2012, 12:57 AM Thread Starter
Ok so I just swapped a 5.0 into an 89 GT shell that I bought. Its got e303 cam, roller rockers, Trickflow street burner intake, MSD cap, wires, 6AL box and blaster SS.
The car will crank but wont start. I had fuel in the rails but no spark. I changed the TFI and now I have spark but no fuel. The pump wont even prime when I turn the key. Now I have no fuel in the rails. I have tried everything I can think of.
Ive checked:
fuel pump relay: has power to pink/black wire and lt blue/orange wire.
EEC relay: I have power at the injectors
inertia switch: have power in and out
all fusible links are good.
have power to TPS
The car will start briefly on starting fluid so I know its a fuel problem. I dont think the pump is bad because its an aftermarket pump that came with the car. And it was working just a few days ago and nothing has changed except I changed the solenoid and the TFI.
Is there anything else that could cause the fuel pump to stop kicking?
Any help would be great guys!
Frankenstang2120 is offline
post #2 of 6 Old 03-17-2012, 10:25 AM
indy2000's Avatar
does the FP relay pull in?
just because you have power to it doesn't mean it works, try ohming the relay coil.
indy2000 is online now
post #3 of 6 Old 04-22-2012, 10:30 AM
An82Mustang's Avatar
try jumping ther fuel pump relay... (all you should have to do is apply a ground that is what the ECM does..) I have had that part of an ECM go bad before...
88 Sonic blue coupe...-
RIP
89 GT Convertible - Sold it!
2000 Kona Blue GT Convertible 4V
2005 Sonic Blue GT
An82Mustang is offline
post #4 of 6 Old 04-22-2012, 10:57 AM
indy2000's Avatar
that doesn't show anything about the signal to the relay.
post #5 of 6 Old 04-22-2012, 01:53 PM
Pretty sure it is pin#22.... This is the ground for the relay... the relay is powered all the time that the key is on... Just gets a grond when the ecm tells it to run. (The fiew seconds of priming and while it receives a signal from the TFI that it is running. ) (This is al so the far left terminal on the diagnostic connector while looking at it with the 2 pins on the bottom...)
RIP
2005 Sonic Blue GT
post #6 of 6 Old 04-23-2012, 01:16 PM
There is a main power relay that needs to come on, in order for the ecu to turn on. No ecu power and you'll get no ground to the fuel pump relay.
However, if you have power on both sides of your inertia switch that tells a lot because it is downstream of all of the above. So if that's true we can know the main power relay works, the ecu is providing ground to the fuel pump relay, and the fuel pump relay works too.
So either you have bad wiring between the inertia switch and the fuel pump itself, or your fuel pump is dead.
Megasquirt
seijirou is offline
Getting fuel to injectors, and spark. Won't start. Need ideas colb71 General Mustang Tech 8 10-29-2011 01:13 AM
97 will crank, start, then shuts right back off... ideas? neato SVT & DOHC 9 09-08-2011 09:11 PM
Wont stay running and wont start without starter fluid. Fuel Problem? Hunter00GT GT & SOHC 7 03-10-2011 11:26 AM
5.4 Swap wont start, Any ideas? 04fivefour GT & SOHC 14 02-15-2011 01:25 PM
No start, Honda Odyssey. trying to fix it like it were a Ford......(long) bolt-on-bandito Lounge 18 01-13-2011 05:23 PM
