fuses or relays? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-09-2012, 02:16 PM Thread Starter
fuses or relays?
Having trouble with headlights. I have no power to driver side headlight. I have high beam but no low beam. headlight is good I looked at fuse box but didn't see any fuse for headlights is there relays then and if so where are they?. My car is a 1981 mustang Any ideas anyone Thanks Jim
furby1952 is offline
post #2 of 4 Old 03-09-2012, 07:38 PM
skeletonpsycho's Avatar
you might have to trace the wires back through the harness if you have power on the left cause i believe there spliced in the front not exactly sure though
skeletonpsycho is offline
post #3 of 4 Old 04-22-2012, 10:38 AM
An82Mustang's Avatar
Check for power at the switch... I think they bolth go to the headlight switch...
88 Sonic blue coupe...-
RIP
89 GT Convertible - Sold it!
2000 Kona Blue GT Convertible 4V
2005 Sonic Blue GT
An82Mustang is offline
post #4 of 4 Old 04-23-2012, 01:31 PM
Check your wires to that headlight socked, and check the socket itself. Both headlights are spliced together in parallel so if one works and the other doesn't, it's not a fuse or a relay or a switch.
I am assuming you know that it doesn't just need a new bulb.
Megasquirt
seijirou is offline
Where is my horn! And why is it blowing fuses? Boozecans 5.0/5.8 Engine Tech 12 09-17-2016 05:14 PM
For Sale Taurus fan, derale fan controller, 75a/80a relays mob Windsor Engine Parts 2 07-13-2011 10:15 PM
relays: are there some better than others? rkloehn General Mustang Tech 3 03-04-2011 08:45 AM
Keep poppin fuses for speedo/radio eleanorfox 94/95 Tech 12 11-23-2010 02:59 PM
What are the two relays under the mass air meter??? d brune 5.0/5.8 Engine Tech 1 12-08-2001 12:18 PM
