Tail light problem... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-06-2012, 06:27 PM Thread Starter
Hello guys, hope someone can help me out. I just bought a set of smoked led tail lights from american muscle and installed them on my 93 Gt. Did not make any mistakes while hooking them up, however the turn signals are not working properly, they work really slow and sometimes they just stop and stay on. The emergency blinkers are working fine. Was told to replace the thermal flasher under the dashboard with an electronic one, did that but still have the same issue.
Any thoughts??
Thanks!
DJM1968 is offline
post #2 of 5 Old 03-09-2012, 07:41 PM
skeletonpsycho's Avatar
i would check the grounds back there and inspect the connector wires
skeletonpsycho is offline
post #3 of 5 Old 03-17-2012, 10:20 AM
indy2000's Avatar
chances are you replaced the hazzard flasher and NOT the signal flasher.
87-89 is attached to steering column, 90+ is next to glove box.
indy2000 is online now
post #4 of 5 Old 04-06-2012, 12:54 PM Thread Starter
Yes, you are correct. I had initially replaced only the hazzards flasher, then found out that the car had another flasher behind the glove box. So everything is working fine now.
Thanks for the responses.
DJM1968 is offline
post #5 of 5 Old 04-09-2012, 05:50 PM
Trader Feedback: (27)
I put those on my 85...I had big reservations but I really like the smoked look! I probably wouldn't buy them again, but they have really grown on me.
droopie is offline
Fox Mustang Tail Light Keeps Popping Out ... HELP wgregan General Mustang Tech 5 12-25-2011 10:19 PM
For Sale RR LX Tail Light Assy (Drilled for "Push Off" Switch) TimP Exterior Parts 7 12-04-2011 09:57 AM
For Sale 1986 gt style Tail light housing and lenses drop top86 Exterior Parts 3 10-28-2011 08:33 PM
led tail light bulb resistor question IRSmart GT & SOHC 2 03-15-2011 11:13 PM
Want To Buy 96-98 lazer red tail light bezels both sides hollyw58d Exterior Parts 0 02-15-2011 09:11 PM
