Wiring in: Trans Brake, VSC, Line Lock, 2 Step, & OD: Suggestions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-05-2012, 09:34 AM Thread Starter
mhinchley's Avatar
Trader Feedback: (44)
I have to wire in a trans brake, varible stall control (Freddy Brown), line lock, 2 Step (PMS), and OD. I am thinking about getting a switch panel that goes into the ash tray. What is the best way to wire these in?
I have a push button on the shifter handle (Hurst) and another remote button that comes with the Moroso line lock if I need to use it.
Obviously the OD just needs to go to it's own toggle, so guess we can throw that out.
I was thinking of running the trans brake, vsc, line lock, and 2 step all to the push button switch on the shifter, but each to individual toggles to activate or deactivate. This way when I am at the line I can activate all and control from the single push button. When heating the tires, I can just activate the line lock. I run the 12v hot through the push button and this will then be the hot supply to each toggle. The toggles in turn will only energize the component they are wired to when each is in the on position AND the push button is compressed.
Is this feasible???
Relay(s) needed?
03 Whippled E85 Cobra Vert & 00 ZX12R
4r70w swap in progress 9-1-14
mhinchley is offline
post #2 of 2 Old 04-20-2012, 07:46 PM Thread Starter
mhinchley's Avatar
Have not decided for sure on the wiring but panel is mounted. Went with a Moroso switch panel and put it in ash tray compartment, blended in place with a plastic epoxy & painted with Por-15. Has reset breakers and mounted them where they will be under armrest. I bought relays, so I will be installing them.
Trans cooler line help StealthStang General Mustang Tech 2 05-01-2011 07:17 PM
c4 trans brake questions daves80capri Drag Racing 4 01-24-2011 05:32 PM
For Sale DYNAMIC RACING C4 TRANS BRAKE 1980cobra Drivetrain Parts 2 01-17-2011 10:05 PM
For Sale Dynamic c-4 trans, pro brake, fresh trink408 Drivetrain Parts 2 01-04-2011 08:28 AM
Want To Trade Art Carr Built C-4 trans brake 1000HP slosvo Drivetrain Parts 3 11-19-2010 11:30 AM
