Fog light mod question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-25-2012, 03:51 PM Thread Starter
I did the fog light mod on my 88 GT this morning but noticed that relay jack 30 or the tan/orange wire runs hot. Is this normal for this mod? Safe to put it back together?
I let all lights run for 20 minutes or so and everything seems to be working great now but just a little concerned about putting it back together.
M109R is offline
post #2 of 6 Old 02-25-2012, 04:35 PM
TrickVert's Avatar
Trader Feedback: (28)
Since I don't know *which* mod instructions you used, I can't comment on the specific potential problem, but, wires should NOT get hot. This typically indicates one of two things: 1) If localized, it is probably a bad connection (crimp/solder,corroded wire) or 2) if the wire itself is warm throughout it's length, it is too small for the amount of current being carried.
You need to figure out the problem and fix it before re-assembling.
If you post a link to the re-wire you did, that might help.
Andy
'95 GT Vert - Rio Red - Grey Leather - Black Top
TrickVert is offline
post #3 of 6 Old 02-25-2012, 06:25 PM Thread Starter
Hey Andy, thanks for the reply.
This is the fog light mod link.
Mustang GT Fog Light Fix
I checked my connections and the connections seem to be good.
The wire itself does not seem to get hot but the connector and relay around that post seems too hot. Wonder if the relay could be bad.
M109R is offline
post #4 of 6 Old 02-25-2012, 06:35 PM
Blown88GT's Avatar
Relay should not get hot. Probably bad crimp at slip-on connector on #30. Solder it.
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
post #5 of 6 Old 02-26-2012, 06:48 PM
87smokemetalic's Avatar
When ever you run a relay for a fan, lights, nos bottle heater, etc .. The relay gets warm, it takes the load off the switch. This is the reason for this mod so your wires to your headlight switch don't melt. If you run a fan with no relay you'll find yourself going through switches if power is going through the switch, some people will use the ground side to switch. But the right way is to use a relay.
87smokemetalic is offline
post #6 of 6 Old 02-26-2012, 07:57 PM Thread Starter
Thanks to all of you for your help....
I soldered the connector #30 and all is well now.
M109R is offline
Want To Buy 94-98 Cobra Smoked Fog Light Lenses & Brackets 1foxbody32 Exterior Parts 3 02-25-2012 02:12 AM
For Sale 99-04 Passenger side fog light white2kgt Exterior Parts 9 08-02-2011 12:02 PM
Fox Fog Light Bulbs ssomustang50 Electrical & Wiring 6 06-11-2011 11:50 PM
For Sale marchal fog light covers questions FS drop top86 Exterior Parts 5 04-20-2011 05:33 PM
Want To Buy fog light switch mustgt98allday Interior Parts 0 04-17-2011 05:24 PM
