which wires?? distributor and fuel pump - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 02-22-2012, 02:32 PM Thread Starter
Im trying to use the stock distributor with a carb set up (6al) what wires do i use to make this happen?
Also useing the stock fuel pump what wires do what where i can still use my stock fuel gauge. going to have pump on a swtich.
Thanks Matt
NotNatural86 is offline
post #2 of 2 Old 03-06-2012, 05:18 PM
SickLX5.0's Avatar
Trader Feedback: (42)
To wire the fuel pump switch I ve used the fuel pump relay's wire before worked well in a pinch when one went out on the road due too not running inner fender walls and moister getting in them and cprroding them on my dd Gt. Idk about the distributer working, didnt think it did. Allways been an EFI guy. No reason why the gauge would work still....
The the two relays are over by ur mass air meter on the fender wall.
SickLX5.0 is offline
