These dam* turn signals!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 02-14-2012, 01:44 PM Thread Starter
SouthernStang's Avatar
So i just recently purchased an 88 lx with a 5.0 etc etc. The turn signals do not work BUT the hazards do..i have researched for days and found alot of people had this problem and it turned out to be the turn signal flasher..na-ah , not here..so after downloading a couple wiring diagrams and wearing out my test light i have come to this..i have NO POWER going to the turn signal flasher plug..It has 2 purple wires with orange stripes coming out of one side and a blue wire out of the other..I figure the ppl/org wires run into the back of the fuse panel at fuse #5 (which of course i could not get a power reading for)Hell if i know where the blue one goes..I understand that there is a grey wire with yellow stripe from the ignition switch connector that supposedly powers fuse #5 and #8..i stick a test light to it with key off key on key backwards and no power but the yellow wires do have power...so it couldnt be the that ign. switch connector right? wtf is going on here? lol i know my problem is obviously no power to the turn signal flasher but im kinda stumped on where it may be losing power at..any help would be TREMENDOUSLY appreciated..thanks
'88 LX Mustang.H/C/I , geared
'87 LX Mustang.H/C/I , Supercharged , geared.
SouthernStang is offline
post #2 of 5 Old 02-15-2012, 02:57 AM
The two yellow wires come from the battery so they should have power. The G/Y wires should have power with the ignition switch in the 'Run' position.
Saleen0679 is offline
post #3 of 5 Old 02-15-2012, 07:07 PM Thread Starter
yes i was messing around and figured that no brainer out yesterday lol..started the car to let it run (been rlly cold lately) and hit the wires with light and they have power to them..same with turn signal flasher..it has power when running but still no turn signals.has got to be the turn signal (multi-function) switch..thanks for the info.
post #4 of 5 Old 03-01-2012, 12:26 AM
Trader Feedback: (38)
check the harness that goes into the 4 way flasher switch... the pins get burnt and pull out ive fixed quite a few of these.... i might have a pig tail if you want with a good plug.... if i have it ill send it for free!
1988 notch
erich306 is offline
post #5 of 5 Old 03-01-2012, 08:08 PM Thread Starter
well fellas i put another turn signal switch in but my problem was the hazard light switch...oddly enough i could squeeze it together after i took it out of the dash and the turn signals would start working..the clips that hold it together where broken.Initially i thought maybe it coulda been the orange wire with yellow stripe running in the back of the hazard switch but turns out it was just a bad hazard switch..i ran a zip tie around it and tightened it up so itd pull it together...the wires were not getting good connection i guess..strange lol
erich it seems like all my plugs are like that..lol
Turn signals not working.. Now fixed but have questions.. sscherin Electrical & Wiring 1 11-28-2011 05:24 PM
Hopefully the rain stops at Dover,,any other Nascar fans??? NJ5pnt0 Lounge 33 05-18-2011 09:57 PM
Turn signals quit working? DeMartino17 General Mustang Tech 6 05-10-2011 10:39 PM
Turn signals come on but do not flash gtcobra302 General Mustang Tech 8 01-15-2011 01:42 PM
