starter solenoids sticking - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-03-2012, 05:29 PM Thread Starter
have a 92 coupe and for some reason the starter solenoid on the fender is sticking. it done this morning so i replaced the solenoid. started once great the second time i started it, it hung and would not quit cranking even with the key out of the switch. so i thought cheap advance auto parts solenoid and went and got a ford solenoid. Got the ford solenoid on and started once great the second time i started it, it hung and would not quit cranking even with the key out of the switch. a buddy said something in the switch could be messed up. I put a new (not reman) starter on it 2months ago and it has been fine until this morning. it does have the old style starter on it (91-back)Any ideas.
TNGT is offline
post #2 of 4 Old 02-06-2012, 06:24 PM
Warlock1's Avatar
Trader Feedback: (23)
Check the actual ignition switch on the column, it may be sticking in the start position.
Warlock1 is offline
post #3 of 4 Old 02-06-2012, 08:41 PM
deathrehab's Avatar
I had the keyed wire slightly exposed and when id crank itwould jump the solinoid and touch the prong for the starter. Doubt its that but it wouldn't hurt to check!
90 lx hatch
Unknown everything-_-
deathrehab is offline
post #4 of 4 Old 02-08-2012, 05:16 PM
Apocolipse's Avatar
Do you have the line to your solenoid fused? If so that's the issue.
Apocolipse is offline
3.8 bell, 5.0 engine, and one unhappy starter... help please! ced715 94/95 Tech 8 05-21-2016 01:52 PM
88 GT w/Mini Starter -- HELP Please TigeRyan Electrical & Wiring 4 07-01-2013 09:24 PM
c4 starter svtlightning208 94/95 Tech 3 09-14-2011 04:15 PM
GM S-10 Techs, ?'s on Starter Issues. Blwn89notch Lounge 9 06-02-2011 12:41 PM
Are all starter solenoids created equal? '89 DropTop 5.0/5.8 Engine Tech 0 01-08-2002 03:04 PM
