Aftermarket EFI-Keep OEM Gauges - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 01-22-2012, 01:33 PM Thread Starter
dart408's Avatar
I'm in the process of installing the Holley Dominator EFI and would like to still keep my OEM gauges on my 1991 LX. I know they all feed through the round brown eight pin connector on the drivers side firewall. I have pulled the engine harness apart and traced all of the wires. Im trying to confirm a few questions I have.
1-White/Red wire goes to oil sender-No question here
2-Red/White wire goes to coolant temp sender-No question here
3-Purple/Yellow wire goes to 02 harness-Had it cut before car worked fine, still don't need it-No question here.
4-White/Purple wire goes to 02 harness-Had it cut before car worked fine, still don't need it-No question here.
5-Red/Blue wire went to TFI module start wire-Will not use-No Question here
6-Red/Green wire went to coil positive, TFI run wire and ECU power relay. Will not be using, no question here.
7-Tan/Yellow wire went to coil negative, TFI module and pin 4 in the 60 pin ecu connector-Does this wire connect to coil negative to feed tach signal ??
8-Gray/Red wire went to Self test port, barometric sensor, coolant temp sensor, air temp sensor, egr sensor, tps sensor, and then to pin 46 of the 60 pin ecu connector. This wire appears to ground wire for these sensors, but also appears on diagrams found at veryuseful.com as the ground wire for the neutral safety switch. Do i just ground this wire so the neutral safety switch will still work correctly and start the car??
408 Dart, Fox Lake Vic Jr's, Proformance Racing TH400 , YSI, Holley Dominator EFI
dart408 is offline
post #2 of 7 Old 02-07-2012, 05:20 AM
88 347 stroker's Avatar
I can check mine out tomorrow. I installed the HP efi in my car. I had a lot of trial and error in getting it set up just right. The guys at Holley are cool and real helpful. I freaking love the HP efi. It is by far the best money I have spent on my car. And it made it run like a completely different engine. I cant praise Holley enough for making a bad ass product.
Enough of my rant. Shoot me a pm with your email n number I can look at mine and call you/email you how I did mine.
88 347 stroker is offline
post #3 of 7 Old 02-18-2012, 03:37 PM Thread Starter
dart408's Avatar
anyone else?
dart408 is offline
post #4 of 7 Old 02-20-2012, 05:54 AM
mustangBrad94gt's Avatar
Trader Feedback: (27)
Originally Posted by dart408 View Post
anyone else?
talk to YELLOWPONEY on ttf, Brad
mustangBrad94gt is offline
post #5 of 7 Old 02-28-2012, 01:17 AM Thread Starter
dart408's Avatar
Do i need a tach adaptor or just hook the tach wire to the msd tach output on the box? I see that all the pre 86 cars need them, but not sure about this 91.
dart408 is offline
post #6 of 7 Old 02-28-2012, 07:34 PM
1991vert's Avatar
i have a big stuff 3. for my tach, i went off the MSD box, works fine
91vert: Dart Block, 363 stroker - all forged internals, AFR185s, Trickflow Box-R, 90mm t/b, CI cam, scorpion 1.6's, Kooks 1 3/4" longtubes 3" coll., 3" custom x-pipe, 3" magnaflows w/ tails, 3.73's, Paxton Novi2000, intercooler
670rwhp/655rwtq @ 17psi (belt slip)
1991vert is offline
post #7 of 7 Old 03-02-2012, 12:01 AM Thread Starter
dart408's Avatar
Thanks!
dart408 is offline
For Sale Saleen OEM White Face Boost + Fuel Pressure Gauges, W/Pics- Ultra Rare!!! PRODIGY Electronics and Entertainment 13 10-23-2011 03:32 AM
? for guys running aftermarket gauges Super-G General Mustang Tech 7 02-26-2011 01:40 PM
Mod Shootout EFI Renegade rules Dave King GT & SOHC 3 12-20-2001 03:46 PM
Proposed Modular Shootout Renegade rules (very long!) Modular Performance GT & SOHC 30 12-19-2001 07:30 PM
