wire harness / pigtail - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 01-11-2012, 06:31 PM Thread Starter
mrau92me's Avatar
I pulled my '87's instrument cluster trim panel off while in the process of replacing my ignition switch. In doing so, I had to disconnect the wire harness from the back of the hazard light switch. I noticed that one of the wires inside the harness was not secure like the others and it can be pulled out of the back of the harness. It doesn't seem like it will make proper contact when I plug it back into the switch. How do I fix this? Can I just plug it back in and then try to use a small tool/screwdriver to push and wedge it up in there?
If it matters, it's the blue and white wire (I think), in one corner of the harness.
mrau92me is offline
post #2 of 4 Old 01-11-2012, 11:34 PM Thread Starter
mrau92me's Avatar
bump
mrau92me is offline
post #3 of 4 Old 01-12-2012, 04:14 AM
One of the little retaining hooks probably broke off the connector. You can get another shell from the junkyard and R&R the wires or you can get a new pigtail and splice or R&R the wires into the new connector shell.
Your other idea of pushing down on the terminal will work also as a temp fix.
Saleen0679 is offline
post #4 of 4 Old 01-14-2012, 04:50 PM
mgt351's Avatar
Trader Feedback: (75)
You can do as already stated and change the connector out with one that isnt broke. One quick fix would be to plug the wire back into its socket then tape all the wires together to keep the one from pulling away.
Sent from my iPhone
14 F150 FX4 Screw
87 Mustang GT terminator swap
70 Torino GT 429 C6
93 LX Notch 333 glide 3.55
mgt351 is offline
For Sale Dual FPDM Wire Pigtail Harness, Newer FPDM, Mounting Hardware risaleen Fuel System & Related 1 11-18-2011 11:12 PM
99 vs early 01 vs late 01 Wire harness differences Twistedoffpurp SVT & DOHC 3 09-20-2011 09:53 PM
New Build with Acel Gen 7 HELP with Wire Harness Ideas? mgmid7070 Engine Management Systems 3 08-16-2011 08:07 PM
Wire Harness PN F6ZZ-14401-AK LX 5.0 5.0/5.8 Engine Tech 5 05-10-2011 06:00 PM
