electric driven alternator is it possible? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 01-11-2012, 01:59 PM Thread Starter
c-ham's Avatar
all right so here is my idea because im always trying to get creative and think of innovative ways to do stuff. Im currently starting an LSX swap on my cobra and am planning to go carbed, manual steering, no a/c, and electric waterpump, so the only thing i will need to drive off my serpentine belt will be an alternator. well i was at work bored and started thinking, they make electric motors that drive waterpumps as a cheap alternative to an electric water pump, what if i just used a similar dc motor to drive my alternator and then i could mount my alternator anywhere in a remote location like perhaps in a box in the trunk with the battery. I know it seems not to make since at first to drive what makes your electricity with electricity, but really the battery will drive the dc motor, and the dc motor will spin the alternator via a belt, and the alternator will in turn recharge the battery.
c-ham is offline
post #2 of 5 Old 01-11-2012, 02:37 PM
Trader Feedback: (40)
Really????
If it worked, we wouldn't need electric companies. That would be the answer to all of our fuel problems.
Sent from my HTC Glacier using Tapatalk
Griggs GR-40 coil over front suspension with Koni SA Yellows w/350# springs in front with Brembo 13" front brakes, EVM Tri-Link, Leda Coilovers w/275# springs in rear. 8.8/9" hybrid rear axles with cobra calipers and rotors. 17x9 real Cobra R with 245/40ZR17 Sumitos.
Rob50lx is offline
post #3 of 5 Old 01-11-2012, 08:17 PM
Conservation of energy
The nineteenth century law of conservation of energy is a law of physics. It states that the total amount of energy in an isolated system remains constant over time. The total energy is said to be conserved over time. For an isolated system, this law means that energy can change its location within the system, and that it can change form within the system, for instance chemical energy can become kinetic energy, but that energy can be neither created nor destroyed.
Conservation of energy - Wikipedia, the free encyclopedia
battery has a fixed amount of energy, we usually use gas/ mechanical methods to recharge. cant use 1 battery to charge the same battery. Losses in friction and heat will make your system fail.
wkornf is online now
post #4 of 5 Old 01-12-2012, 01:07 AM Thread Starter
c-ham's Avatar
i had high doubts this would work because it seemed to be such a nice idea that it must not be possible or people would have done this a long time ago lol thanks for the info
c-ham is offline
post #5 of 5 Old 01-17-2012, 01:32 PM
Jbone's Avatar
Smokey Yunick did a fan driven set up years ago. Of course officials said he was cheating
My build- http://www.horsepowerjunkies.com/forums/showthread.php?t=111446
Jbone is offline
For Sale 93 PROCHARGED NOTCH ELECTRIC CURRANT RED CRZ5LTRKID Mustangs For Sale/Wanted, 1987-1993 72 02-06-2013 12:25 PM
Can I use electric wire and electric rope together from6to8 Lounge 8 03-31-2011 01:04 PM
Small Carb Electric fuel pump- No regulator?!?! masterjr33 5.0/5.8 Engine Tech 9 03-01-2011 09:03 PM
Are electric water pumps really that helpful? XSPOWER 5.0/5.8 Engine Tech 36 02-22-2011 09:17 AM
Electric Water pump for daily driven use? ekoster 5.0/5.8 Engine Tech 6 12-12-2001 03:09 AM
