Electrical problem help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 01-07-2012, 01:35 PM Thread Starter
ChromeCobra's Avatar
I'm am having a problem with my '98 Cobra that I just cannot figure out. I searched threads and found that people have had the same problem but I couldn't find a solution to it.
Gauge cluster, HVAC control, license plate, and parking/running lights do not illuminate. The headlights, foglamps, turnsignals, and brake lights do still work perfectly though.
The #13 fuse was blown, I replaced it and they still don't work. I also replaced the headlight switch and that also didn't fix anything. I checked all obvious wires and grounds and everything looks good.
Does anyone have any ideas?
ChromeCobra is offline
post #2 of 4 Old 01-07-2012, 09:03 PM
Is fuse #5 good?
Saleen0679 is offline
post #3 of 4 Old 01-07-2012, 11:05 PM Thread Starter
Every fuse is good, thanks though.
post #4 of 4 Old 01-08-2012, 08:16 PM
What about connection behind the fuse box? I had a wire burn in half one time and cause similiar problems. Especially considering the blown fuse. Take a DMM or test light over the fuse with power on to make sure there is power on the fuse.
Leeiswho2b is offline
89 lx electrical problem??? chris306 General Mustang Tech 4 08-25-2011 10:14 AM
89 electrical problem HELP chris306 Electrical & Wiring 1 08-24-2011 11:02 PM
is it my transmission? or is it an electrical problem? notchahead93 General Mustang Tech 1 11-23-2010 06:47 PM
What's up with the rough idle? Maybe electrical problem? progresr GT & SOHC 10 07-03-2003 08:58 AM
Electrical problem: instrument panel lights won't turn on ASpaceman General Mustang Tech 15 02-11-2002 11:15 AM
