Where to get 2/0 gauge wire? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 12-28-2011, 10:41 PM Thread Starter
I'm looking to relocate the battery to the trunk and want to do a decent job and I want 2/0 gauge cable from the battery to the engine - both on positive and negative. I can't find it anywhere apart from one place on ebay that will only supply in weird lengths for boats - the one I may get if I can't get it anywhere else is a 10ft length - that should bring me to the engine bay correct?
Any advice on length or where I can get the cable is appreciated.
I think it's amazon not recognizing 2/0 and won't give me 00 either.
Thanks all
Reverb is offline
post #2 of 8 Old 12-29-2011, 02:11 AM
Have you checked out any welding shops?
DavidEwers is offline
post #3 of 8 Old 12-29-2011, 08:31 AM
jconnor3's Avatar
Thats what I did. Went to a welding shop and I think they call it lead line, either way it's the line from the welder to the clamps they use. It was pretty cheap and you can get whatever length you want. Went to NAPA and had them clamp on the right ends that I needed. Worked great.
2002 Sonic Blue GT Vert - Mostly stock....so far
68 Mustang Coupe: 2001 Explorer motor/GT-40P heads/Weiand Action Plus intake/ TFS Stage 1 camshaft/Power Steering/4-wheel disk brakes/T-5
jconnor3 is offline
post #4 of 8 Old 12-29-2011, 09:18 AM
keithnra's Avatar
Trader Feedback: (29)
i just got mine at napa
89 GT convertible 5.0 GT40 irons BBK 70mm TB,
66 289 bored .40 over Holley 600 comp cam
99 GT
99GT vert
keithnra is offline
post #5 of 8 Old 12-29-2011, 11:33 AM Thread Starter
Cool thanks. Is 10ft too much?
Sent from my HD7 using Board Express
1970 Mach 1 Mustang with SoT bilsteins and mid-eye 4 1/2 leafs 620lb drop springs in the front. *393 4V cleveland with Buddy Rawls custom solid cam Astro A5*
Reverb is offline
post #6 of 8 Old 12-29-2011, 12:48 PM
crownvicon26s's Avatar
weldingsupply.com
crownvicon26s is offline
post #7 of 8 Old 12-29-2011, 02:15 PM Thread Starter
Originally Posted by crownvicon26s View Post
weldingsupply.com
Thanks - hadn't thought of welding supply places - only audio and jumper cables. So I'm going to buy 10 ft of red and 12 of black.
When you run the earth to the engine bay do you go straight to the block then run the other earths from there - or to a patch box?
Reverb is offline
post #8 of 8 Old 12-29-2011, 03:28 PM
If they have aluminum wire line get that, it will be more expensive but about half the weight.
alternator wire 93LX KennethRisher Electrical & Wiring 1 04-02-2011 02:02 AM
Temp Gauge Problem need help jdwyer25 SVT & DOHC 5 03-14-2011 10:23 PM
Serious questions dilemma about mechanical oil PSI gauge and DOHC oil PSI readings Cobra Jet NJ GT & SOHC 11 12-14-2001 04:19 PM
Auto Meter Air/Fuel gauge, which o2 sensor wire??? Stallion Motorsports 5.0/5.8 Engine Tech 3 12-08-2001 05:59 AM
