another turn signal problem, 88 gt - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 12-02-2011, 11:51 AM Thread Starter
mn12xr7's Avatar
Ok well my 88 GT's turn signals dont work. The hazards do, now when I flash the high beams they turn on but when I turn on the signals or turn on (not flash) the high beams, they dont work. I got another multi function switch that I had that works and no luck. Made sure the connections were tightly fit, made sure the #5 fuse is ok and and replaced the flasher behind the fuse box and in the steering column.
any thoughts?
mn12xr7 is offline
post #2 of 5 Old 12-19-2011, 07:51 PM Thread Starter
mn12xr7's Avatar
could this be the ignition switch? I did a search and thats what I can come up with.
mn12xr7 is offline
post #3 of 5 Old 12-21-2011, 06:02 PM
Check your flasher relay
wraitherx is offline
post #4 of 5 Old 12-21-2011, 08:41 PM Thread Starter
mn12xr7's Avatar
i did, and replaced it
mn12xr7 is offline
post #5 of 5 Old 12-22-2011, 03:08 AM
xploder17s's Avatar
fuse, relay, multi switch.
have fun, blow it up, and take pictures.
xploder17s is offline
94 GT, Turbo + Digital 6 = problem! 2dxtrm 94/95 Tech 20 06-26-2011 01:54 PM
Want To Buy turn signal switch connectors mn12xr7 Interior Parts 1 06-16-2011 02:41 PM
Turn Signal Issues 1993 Ford Mustang gsoublis General Mustang Tech 5 04-28-2011 11:04 AM
Axle Bearing Removal Problem in 95 GT - Help! lo pony 5.0/5.8 Engine Tech 3 01-14-2002 06:14 PM
