Can somone id this wiring harness? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 11-17-2011, 08:05 AM Thread Starter
keithnra's Avatar
Trader Feedback: (29)
i have a wiring harness that i need someone to id for me
im pretty sure its either a 90 or 91 or 92
Uploaded with ImageShack.us
89 GT convertible 5.0 GT40 irons BBK 70mm TB,
66 289 bored .40 over Holley 600 comp cam
99 GT
99GT vert
keithnra is offline
post #2 of 10 Old 11-22-2011, 08:29 AM
Spammer/Banned
1990
post #3 of 10 Old 11-27-2011, 06:07 PM
Blackfive0's Avatar
Trader Feedback: (62)
yes 1990
Blackfive0 is offline
post #4 of 10 Old 12-21-2011, 05:29 PM
Xstang82's Avatar
its 87-89
Xstang82 is offline
post #5 of 10 Old 12-21-2011, 06:04 PM
mgt351's Avatar
Trader Feedback: (75)
Originally Posted by Xstang82 View Post
its 87-89
Not with airbag plugs its not ( white connectors in pic)
90 model
Sent from my iPhone
14 F150 FX4 Screw
87 Mustang GT terminator swap
70 Torino GT 429 C6
93 LX Notch 333 glide 3.55
mgt351 is offline
post #6 of 10 Old 12-21-2011, 08:08 PM
Xstang82's Avatar
your right. i didnt see the bottom picture. it a 90 harness
Xstang82 is offline
post #7 of 10 Old 04-01-2012, 06:15 PM
ill ask a questionm kinda on this subject...i have a 90 vert and swapped to a 93 eec harness...the 93 has a brown connector at the booster where it connects to the body harness and the 90 has a gray connector..they snap together smoothly but are the wires corresponding?
90notch308 is offline
post #8 of 10 Old 04-01-2012, 07:37 PM
mgt351's Avatar
No they will not match up and you should have a second plug on your harness, the 93 only has the one.
14 F150 FX4 Screw
70 Torino GT 429 C6
mgt351 is offline
post #9 of 10 Old 04-02-2012, 07:32 AM
which pins need swapped? yes the 90 had a black connector as well....
post #10 of 10 Old 04-02-2012, 11:03 AM
mgt351's Avatar
Its more than just swapping pins. The 93 harness has a fuel pump relay in the engine harness. Yours has one in the body harness under the drv seat. You would be alot better off getting the correct harness.
14 F150 FX4 Screw
70 Torino GT 429 C6
mgt351 is offline
For Sale 87-93 wiring mass air , o2, headlight, dash , rear harness ias97 Electronics and Entertainment 4 09-28-2011 04:47 PM
99 vs early 01 vs late 01 Wire harness differences Twistedoffpurp SVT & DOHC 3 09-20-2011 09:53 PM
For Sale full wiring harness from 90 5.0 vert mygreengt Electronics and Entertainment 2 09-09-2011 08:57 PM
Fox dash harness wiring - premium speaker harness present?? Mustang5L5 General Mustang Tech 4 02-23-2011 02:00 PM
For Sale 1989 Mass Air Wiring Harness and A9L Computer With Injector Harness 350.00 P/S mustangt66 Electronics and Entertainment 1 12-20-2010 11:33 AM
