Code 18 with 22K ohm resistor - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 11-16-2011, 01:15 AM Thread Starter
fiveohfanatic's Avatar
So I have had a erratic tach with starting my 93 mustang. No other problems until I installed a CAI/mass air, after doing a base idle reset and thinking all was well, I started to move the car and it died, almost instantly with load. Its not stalling, it just dies.
So pulled codes, got code 18, did a search, and found a lot of discussion about this item, 22k resistor. So it goes from the TFI to coil, and branches off to pin 4 on the EEC.
I tested resistance between the pin on the TFI to the coil, everthing unplugged from its connector and got minimal to no resistance on my meter. If that resistor is good, should I be seeing roughly 22K ohms? Below is a pic, I plan on fabbing up a replacement after a trip to radio shack.
2003 Silver Cobra
1993 notch
fiveohfanatic is offline
The DREADED code 34..arrrrggg Mr. Blues 5.0/5.8 Engine Tech 4 04-06-2011 01:56 PM
Who has access to Oasis reports? straightliner1 Lounge 4 02-28-2011 01:19 PM
Code 34. Replaced EVP. Code still there. dannyUAL91GT 5.0/5.8 Engine Tech 12 01-04-2011 11:29 AM
It was code 32; now it's code 33 Jack Straw 5.0/5.8 Engine Tech 0 12-14-2001 05:34 PM
Experience using EEC-IV code reader? Whiterag 5.0/5.8 Engine Tech 1 12-09-2001 05:03 PM
