Anyone know what this wire branches off into?! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-05-2011, 07:00 PM Thread Starter
My starter wont shut off once the car is running, by removing this wire from the starter solenoid the car wont start at all, once it is applied, the car starts and the starter stays on, I need to track down the 3 wires it branches off into and am trying to avoid cutting into all the conduit on the car to do it the dirty way... Any help is appreciated.
Thanks, Allen!
SSRMUT8 is offline
post #2 of 2 Old 11-08-2011, 11:22 AM
Blackfive0's Avatar
Trader Feedback: (62)
That yellow wire should be hooked up to 4 fuse links. You can see here. One of the those wires goes to the fuel pump relay.
http://www.veryuseful.com/mustang/te...nks-ign-ac.gif
If the start will not shut off when the car is running have you tryed checking the starter solenoid.
Blackfive0 is offline
New Build with Acel Gen 7 HELP with Wire Harness Ideas? mgmid7070 Engine Management Systems 3 08-16-2011 08:07 PM
Adios old kitchen, it's been a fun-filled disgusting last 3 years. Dave88LX Lounge 258 05-05-2011 09:09 PM
3G installed???exciter wire voltages?? Eleanor68 Electrical & Wiring 0 04-29-2011 12:55 PM
alternator wire 93LX KennethRisher Electrical & Wiring 1 04-02-2011 02:02 AM
