Tach acting wierd after replacing odometer gear (video inside) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-04-2011, 06:35 PM Thread Starter
Tach not working properly after replacing odometer gear - YouTube
I recently replaced my broken odometer gear. Before removing gauges all gauges worked fine(except odometer). After I re-installed gauges it seems all gauges on the right side are not as smooth and as accurate as they were before. The Speedo works great and as far as I can tell I have no issues with the fuel and water temp gauges.
As you can see in the video the needle seems stuck at a certain position until there is a significant change in needle position. So the needle is not smooth and not as accurate or as responsive as it should be. I've taken the gauges back apart and put back together several times to see if I could see or even fix the issue. I have no idea what is causing it. Any ideas? Thanks for your help.
This is on my 98 GT
Mustang98y is offline
post #2 of 2 Old 11-15-2011, 03:27 AM
BLOWNCO's Avatar
looks like its sticking to me try resetting the needle
BLOWNCO is offline
Tags
guage, guages, tach, tachometer
First gear install - gear pattern pics inside rickyll7 General Mustang Tech 12 04-24-2011 12:56 AM
video - 3rd gear burnout CorralTV Video 3 02-13-2011 04:22 PM
Help AOD Speedometer Recalibration SAS General Mustang Tech 13 12-28-2001 07:23 AM
Best way to calculate what speedo gear is needed? d brune General Mustang Tech 5 12-18-2001 07:54 AM
