93 Cobra Electrical Problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 10-28-2011, 10:35 PM Thread Starter
Well the headlights and turn signals are not working for some reason however when i put the hazards the turn signals do work.... Also to use the my lights I have to use the highbeams but they wont stay on, i have to grab the turn signal switch to use them...anybody know what it could be, I checked the fuses under the steering wheel and they are all fine
07BlackStang is offline
post #2 of 8 Old 10-28-2011, 10:57 PM Thread Starter
Another thing i noticed is that they changed the headlight switch cause it only has the switch for headlights and not foglights might that be the problem
post #3 of 8 Old 11-03-2011, 09:39 PM
The headlights should work, even with the LX switch. Pulling the turn signal stalk back towards you will flash the high beams like you mentioned. Pushing it away from you is how you turn them on all the time.
Will the high beams come on when you push the stalk forward with the headlight switch on?
Megasquirt
seijirou is offline
post #4 of 8 Old 11-10-2011, 12:10 PM
Seasoned User
Trader Feedback: (97)
Check for wires coming out of the connector behind the switch I've had this happen In the past.
Animal is offline
post #5 of 8 Old 11-10-2011, 04:40 PM
ftgt101's Avatar
Kind of sounds like your multi switch. I am no expert by any means, but try changing out the turn signal stalk. See if that works.
1968 Mustang Coupe Fuel injected, 1993 Cobra Teal w/Black Cloth, 1982 T-Top 351w Vortech S-trim, 2016 Mustang GT
ftgt101 is offline
post #6 of 8 Old 11-15-2011, 11:19 PM Thread Starter
i bought a new switch and now my headlights work properly now the only thing is that my turn signals still are not working, hazzards work fine but not the turn signals I changed the flasher that is under the steering wheel and still a no go
post #7 of 8 Old 11-16-2011, 05:48 AM
I had the same problem your having now with the turn signals. The highlbeams, wipers with delay, and hazard lights all worked fine, so I know it wasn't the multi switch, I even swapped the switch out with a known good part and still had no turn signals, it ended being the ignition switch. It started to come apart where the main harness plugs into it. Try taking a look there, hopefully thats the problem.
redkoa5 is offline
post #8 of 8 Old 11-20-2011, 09:14 PM Thread Starter
well had the problem fixed already it turns out that the wires from the realy that´s behind the glove box were somewhat loose and that was causing the problem
For Sale Lots of SN95 GT & Cobra Parts bmwm3 Modular Engine Parts 26 03-26-2012 04:03 PM
96 cobra 4v fuel trim problem cp cobra SVT & DOHC 15 09-11-2011 08:52 PM
For Sale 93 Cobra, Custom white with 408 aaronlstiles Mustangs For Sale/Wanted, 1987-1993 2 07-03-2011 03:39 PM
Are all 95 Cobra's "SVT" hinge 94/95 Tech 22 02-08-2011 06:24 PM
For Sale Complete 01 Cobra 4v engine the1silverbullet Modular Engine Parts 17 02-03-2011 04:19 AM
