help hooking up relay - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 10-19-2011, 10:54 PM Thread Starter
I bought a hayden 3647 to hook up my electric fan and intended to replace the included 40amp relay with a higher amp 75 one. Now that I have the parts in hand the relay design isnt compatible with the controller. What are my options here? Should i just return the relay and look for different model? Or should I get some sort of spade connectors and make a harness?
Thanks,
Wayne
Hayden 3647
Tyco 75 AMP
wkornf is offline
post #2 of 5 Old 10-20-2011, 01:54 PM
Those wires aren't large enough to handle 75 amps.
If you need to run a 75amp relay you'll want to make sure whole system is designed for it.
What kind of fan do you have that 40amps won't be adequate?
Megasquirt
seijirou is offline
post #3 of 5 Old 10-20-2011, 07:53 PM Thread Starter
im pretty much following this guide
Junkyard Electric Fan - FordMuscle
The way i understand it the taurus fan pulls about 30-40 amps under steady operation but much more at startup. The larger amp relay is there to reduce the chance of having to change out relays often.
Looks like in the the ford muscle guide they managed to get a 75amp relay with the same dimensions as the original.
wkornf is offline
post #4 of 5 Old 10-20-2011, 08:11 PM
I see. Well if it's just momentary, then those wires will be okay. I would just use some spade terminals and run wire between the controller and your new relay like you mentioned.
Megasquirt
seijirou is offline
post #5 of 5 Old 10-20-2011, 08:19 PM Thread Starter
Sounds good. Ill see what happens next time I get a chance to work on it.
Thanks,
Wayne
wkornf is offline
Rewiring WOT relay SVOJOE General Mustang Tech 12 03-15-2019 03:21 PM
Fuel pump relay issues, HELP PLEASE jonyboy107 General Mustang Tech 4 07-29-2011 11:22 PM
Need help hooking up fan relay slowman9786 General Mustang Tech 4 12-15-2010 05:01 PM
Help a wiring retard - RELAY Vettkilr 5.0/5.8 Engine Tech 2 12-16-2001 07:59 AM
