Battery Terminal Suggestion? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 10-19-2011, 02:41 PM Thread Starter
While doing my dual FPDM upgrade, I noticed the poor choice of battery terminal from the PO. The terminal appears to be too small for the cable, and it only has 2 accessory ports, both used for the stereo system. I need a third for my wiring upgrade to the dual FPDM.
Does anyone have any suggestions on a good terminal to use, or another conifguration that would work fine? Worst cast scenario I can use a clamp terminal and add on one of the accessory extensions to it.
WickedSnake00 is offline
post #2 of 2 Old 10-19-2011, 08:56 PM
use one of the accessory ports to a multi outlet distribution block that has fuses for each output. easily found at any sound store.
90 coupe, 302,9.7 comp,scat rods, ported windsor sr.'s(286 [email protected]" 2.05/1.60),tfs stage 3 cam,
funnel web, 750dp,c4/4000,4.30 gears, aeromotive 140 pump-motor/holley red for nitrous, 16 gal. cell, 2 stage nitrous,M/T 28x9 et drag,5" cowl hood.
tim harris is offline
For Sale Used Taylor aluminum battery relocation kit Begizzle Electronics and Entertainment 7 10-16-2011 05:52 PM
Battery Keeps on Dying jdballa40 5.0/5.8 Engine Tech 7 12-21-2010 11:49 AM
Did I damage my Optima battery? Pegasus71 5.0/5.8 Engine Tech 10 01-02-2002 01:05 AM
Summit Battery Box Good--Summit Wiring Kit Bad! LXguy 5.0/5.8 Engine Tech 2 12-04-2001 11:26 PM
